Old 10-23-2002, 04:44 PM   #1
nu2-72
14 bolt FF ???'s
I am now in the market for a replacement for my 3/4 ton rear end. I have the Eaton 10 bolt and want a 14 FF. Is there a prefered year and engine to locate a 3:73 axle ? Or do I just dig through salvage yards til I find one ? I will also be changing the front axle to 3:73 at a later date. Where is the best place to find a Dana 44 with 3:73 ? Or should I just buy gears and install them into my case ? Thanks.
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
2004 Duramax Silverado 4x4
2006 Duramax Crew cab 4x4
2010 Harley Ultra Limited
2011 Harley Street Glide
nu2-72 is offline   Reply With Quote
Old 10-23-2002, 07:44 PM   #2
Blazer1970
Blazer1970's Avatar
Most 14 bolts are 4.10 or 4.56. For 3.73s, you might look for a truck with a diesel. There are some 3.73 axles out there. If you don't want to move the spring pads, you will need one from a one ton truck, not 3/4 ton. Shock mounts will have to be moved on any 14 bolt to be used in your truck. 3.73 D44s are common in 4X4s from the '67 - '72 era. You would want to look for a '71 or '72 to get disk brakes, and most 6 cyl. trucks will have the 3.73s.
Blazer1970 is offline   Reply With Quote
Old 10-23-2002, 07:51 PM   #3
Beast388
Suburbans RULE!
Beast388's Avatar
Any SRW 14 bolt FF will work, but if you find one from a single rear wheeled 1 ton, the spring perches will be 40.5" apart........which is what you need for a 67-72 truck. You can use one from a 3/4 ton but the spring perches are at 42" so they will need to be moved.
You will also need to move one of the shock tabs so they are both on the front of the axle.
You may also want to check u-joints size and parking brake set-ups, there may be some differences.
--Ben
71 GMC Suburban 4X4
The "Beast"
388 CID Stroker, TH350, NP205, 8-lug D44, 14BFF w/ Detroit, 4.10:1 gears, 4-Wheel Disks 4" Lift, 35" MT/R's.
Beast388 is offline   Reply With Quote
Old 10-23-2002, 07:55 PM   #4
Beast388
Suburbans RULE!
Beast388's Avatar
Blazer1970.....you are a fast typer!!
If are looking for a Dana 44 to match the 14bff....get one from a 1977-up 3/4 ton. These use the internal hubs as well as the stronger 297X ujoint axle shafts. Obvioulsy just make sure you match the gear ratios front to rear.
--Ben
71 GMC Suburban 4X4
The "Beast"
Old 10-23-2002, 09:32 PM   #5
nu2-72
Thanks guys. I either need a five speed or a gear change. The 4:10's are killing me and since I never use 1st gear now, a rear change would give me the top where I need it and still have a good low. I will also be going to disc in the rear so I want to get started now.
Does the 77 have the same large style hubs that my 72 has ? Am getting new large hubs and would hate to not use them.
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
Old 10-23-2002, 09:51 PM   #6
Ratpowerd67
NU2-72, I WAS LOOKING FOR A FF ALSO. I FOUND THAT MOST AUTOMATIC EQUIPT TRUCKS HAD 373. AND THE 4 SPEED HAD VERSIONS HAD 410 AND UP.
Ratpowerd67 is offline   Reply With Quote
Old 10-23-2002, 10:08 PM   #7
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Kevin, stay away from 14 bolts from vans as they are wider than the truck rears, as for your large lockouts you will have to use the wheel hubs from the 44 you have now on the later model axle in order to use the large spicers, spindles and stub shafts are the same. I talked to a guy from Leavonworth at the Woodlands swapmeet that had a 3:73 14 bolt for sale[I think 200.00] and had a lot of chevy 1 and 3/4 ton driveline parts, I got his number if you need it.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 10-23-2002, 10:56 PM   #8
6869704X4
hmmmm.. I got a van 14bolt because it was wider. I want the rear width to more closely match the front.
The more I learn about women, the more I love my truck.
6869704X4 is offline   Reply With Quote
Old 10-24-2002, 02:05 AM   #9
Fred T
Cantankerous Geezer
Fred T's Avatar
Take a tape measure, too and check the width. Most that I have found in 3/4 ton pickups were the same width, the one tons are different. Also if the one ton didn't have beveled nuts, the studs will be severely worn and require stud replacement. The vans that I looked at were not only wider, but semi-floaters. A good junkyard can tell you which truck you need to look at. If they can't, I go on down the road and find another yard.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 10-24-2002, 03:29 AM   #10
lost wages
lost wages's Avatar
i have a 14 bolt ff here in missouri i would sale, it came from a 76 single wheel ton truck. I am not sure of the ratio but if some one will tell me what to check i can find out.
lost wages is offline   Reply With Quote
