02-21-2008, 01:12 AM | #1 |
1975 C-10 Silverado LWB
Shortening a Longbed
I have a 1975 C-10 LWB. Its a Heavy Half and its been sitting in the drive way for a while. Just been cleaning it up and saving up cash to get the project really started. There is some damage to the bed that I am not fond of paying to get fixed, and every trip to the pick 'n' pull I keep seeing trucks with really nice condition short beds. all the long beds seem to be beat to hell :\
I've been thinking about it so how hard would it be to make my long bed a short bed? I have seen the article on 73-87.com, but it sounds too easy... Anyone done this, and any advice or tips/tricks? Thanks in advance, Jared
1975 LWB C-10 Silverado - Stock - "BIG 10" - 4 Bolt 350 "Brand new" 1200mi - THM-375 "Brand new w/trans cooler" 5000mi 1995 Ford Lightning - Bone Stock - 351W - Vortech?? |
02-21-2008, 01:35 AM | #2 |
Dirteh Kitteh
Re: Shortening a Longbed
Jared, it's funny you should ask. I just saw a show on Speed Channel about this very thing. The hardest part of it is the bodywork to the bed (which you wouldn't be doing if you bought a short bed) and next is the driveshaft, which if you picked the one up out of the truck you got the bed from solves that problem.
The frame is just a matter of measuring VERY carefully and cutting out 12 inches of it, moving the rear cab mounts, then welding it back together. Just remember not to hack the frame with two plain cuts per side, it needs to be a notch cut so the welds putting it back together are strong enough.
Darrin 1955 Willys CJ-5 all original and the oldest CJ-5 on the road. 2001 Dodge Neon (wife's car) 1995 Jeep Grand Cherokee Limited Edition SOLD 1981 K15 Custom Deluxe 4X4, rusty but trusty wood hauler. SOLD 1993 S-10 4X4 Tahoe SOLD Sign up with the Contact List RIP ESLL |
02-21-2008, 01:44 AM | #3 |
Cruzzzn' Vet
Project Get Shorty in the July 07 issue of Custom Classic Trucks has an article of them shortening a 71 longbed to a shorty, lots of pics.
02-21-2008, 01:52 AM | #4 |
Thinkin a nothched cut is not required. The filler material of welding wire or rod is stronger then mild carbon steel. A 100 percent pentatration weld should be obtained. Generally problems with welding is operator error. I happen to be a welder by trade.
02-21-2008, 02:46 AM | #5 |
What frames are the same for the earlier trucks? (67-72)
02-21-2008, 03:49 AM | #6 |
Dirteh Kitteh
What I meant by a notch cut is to cut half way down the frame rail, then cut horizontally back 12 inches, then continue the downward cut. Then cut the match to it out of the back part of the frame. That way when it goes back together there's a 12" section of cross brace between the two parts of the vertical cut. They did that on the Truck U (I think) show where they did a long bed to short bed conversion and they said that it increases the strength of the weld-together 3 times as strong versus just making a single vertical cut and welding it back together.
02-21-2008, 04:54 AM | #7 |
where can i find the july 07 issue of CCT? I cant find anything on their web page.
02-21-2008, 05:50 AM | #8 |
67-72 parts collector,…
Actually,... since the 73-87 trucks are leaf spring,... you can shorten the wheelbase directly behind the cab without messing with the cab mounts. (like you have to with the 67-72 coil spring trucks) Maybe some one will chime in,.... that has done this,... but I think the wheel base gets shortened 14 inches on the 73-87 trucks. Plus you have to trim the frame in the rear also. Someone has done this before, on this board. Try to search the 73-87 section or the suspension section. I think the numbers are different than the 67-72 trucks. The tech article on www.73-87.com was the one I remember. Here's a link for everyone.http://www.73-87.com/7387garage/chas...lwb_to_swb.htm
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 02-21-2008 at 05:56 AM. |
02-21-2008, 06:47 AM | #9 |
www.73-87chevytrucks.com
There is a guy on my forum that is about to start doing this on his 74 LWB. His post today said that tomorrow is its last day as a LWB.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
