Old 02-21-2008, 04:44 AM   #1
Cameo Carrier
Cameo Carrier's Avatar
Radiators
How can I tell between a 6 cyl. and an 8cyl.
Is that a camaro bed on that?
Cameo Carrier is offline   Reply With Quote
Old 02-21-2008, 05:02 AM   #2
pugs
pugs's Avatar
Re: Radiators
only differencei had seen was the numbers of core rows, 2 or 3 , but i used 6cyl rads for a V8 with out any problems
I don't do thing cuz I can, I do it cuz someone told me it couldn't be done...
pugs is offline   Reply With Quote
Old 02-21-2008, 10:22 AM   #3
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Radiators
The V8 is slightly wider and taller. I have used 6 cyl radiators with v8's and not had a problem as long as the radiator is clean.
dwcsr is offline   Reply With Quote
Old 02-22-2008, 02:52 AM   #4
Cameo Carrier
Re: Radiators
The reason I ask is that I was using a buddys and he had different numbers on his. They looked to be the same size but mine has wider fins but less of them. Both seem to do a fine job with the 350 that is in my truck.
Old 02-22-2008, 04:21 AM   #5
Atomsplitter
Atomsplitter's Avatar
Re: Radiators
I'll assume you guys are talking about 55 to 59 v8 radiators?
I have a '48 and I was wondering if there was a difference between the 1/2 ton radiator as compared to a Big (2 ton) truck radiator of the same year?
Should I start my own thread for this question?
Atomsplitter is offline   Reply With Quote
Old 02-22-2008, 04:26 PM   #6
54 jimmy
54 jimmy's Avatar
Talking Re: Radiators
atomspliter the 47-54 1/2 tons were 2 core rads and the 1 1/2 up were 3 core rads if that helps u out. no difference in measurements just the core size.
54 jimmy is offline   Reply With Quote
Old 02-23-2008, 12:58 AM   #7
Atomsplitter
Re: Radiators
I actually have one of each (1/2 ton and a 1-1/2 Ton) of these radiators and one is about 2/3 as thick as the other. So a long as the 1-1/2 Ton radiator is clean and leak free it should be OK for my Fuel Injected 350 @ 300hp?
