Engine n00b
3 screws = 1 hour
Ever have one of those tasks that you think is simple, and then you spend an hour on them.
I replaced ONE of my exterior mirrors today. Screws were all but welded in there... drilled them out. Backing plate fell into door. Specialty tool and 2 more screws and I found the backing plate, plus a door thumb button, a spring, and a piece of hornet nest (wtf) in there. PBblasted it, and used visegrips to get those drilled studs out and somehow didnt ruin the threading (phew) Had to get the girl to start the new screws cause I dont have 4 arms Bolt it all back together, and GOLLY... I have a shiny new mirror and hardly any damage to the truck! (some paint was lost in the yanking of the old mirror, oops) Some days, ya just feel like you are worthless even with all the right tools. |
Re: 3 screws = 1 hour
Some times you start on something and the whole can of worms spills out. That's the thing with something that's been around for 40 years, I guess, especially trucks. Fix it whatever way you can.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD ![]() Click here to support the board Philippians 4: 6-7 |
#3 | |
Engine n00b
New place doesnt have a garage (or even a paved driveway) I might have to convince our landlord that a paved driveway will increase property value ![]() |
Nothing to see here.....
![]() Join Date: Jun 2007
I know this is a bit late, but put a dap of silicone on the backing plate and it'll stay there the next time you have to remove it.
Doug ![]() ![]() The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
Engine n00b
Will it run today?
Not truck related, but I totally understand. I have a hole in my kitchen island where a sink used to be. Had a clogged drain, so had to clean the trap. Needed more room to snake the trap, so removed the disposal. Found the disposal to be full of rust. Removed disposal from sink, but vinyl sink was old and cracked when removing the disposal. Had to take the faucets off to get the sink out and one of the faucets broke because PO tightened the nuts too hard. So...
drain snake - $20.00 new faucet - $50.00 new sink - $100.00 new disposal - $169.00 Wife who refuses to properly to use disposal - priceless, er... $339.00
Jaws, the 1971 Chevy Cheyenne Longbed. She's big, grey, and has an insatiable appetite! Last edited by Chevyholic; 02-21-2008 at 09:47 AM. |
wow you had that much trouble with mirrors? geez. try some PBblaster next time...wait till you replace the rubber in a pair of vent windows. youll be ready to take a hammer to your nut sack!!..no really..
#8 | |
I have a radical idea!
OK, I've done the vent glass rubbers before, and I agree - they do suck, but it wasn't THAT bad!!! ![]()
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
blood type; Retumbo
try doing that one bell housing bolt on a 96 S10 Blazer. the one on the top of the driver's side. hehehe.
Engine n00b
I used to have a WRX. The plugs on that were amazingly knuckle bleedingly hard.
about .5 inches between the plug hole (which was 3" deep) and the side fender. people with lifts would lift the engine to get more room (or jack it) Annoying. But yea, just more than I expected. And I couldnt really PB blast the inside of the door skin when I started... I did the outside, but it just didn't want to penetrate. The upside... my drivers side mirror no longer has Micheal J Fox syndrome. |
#11 | |
The Older Generation
![]() LockDoc
yes, i do
yeah the can'o'worms is what happened when i broke a tap in my block when i was changing head gaskets. couldn't find the right size tap extractor, no parts store or hardware store or tool store had anything that even slightly resembled a tap extractor, trying to find some kinda tool to use as a tap extractor, one hour in a weld booth and 6 nuts later the tap was out. god i just wanted to put my head through a wall with that whole fiasco.
ERROR 404....... SNAPPY COMEBACK NOT FOUND ![]() _______________________________________________________________________________________________ -60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination" -07 gmt900 silverado 1500 lt xcab z71, granite blue -81 suzuki gs650g "shelah"- current project -81 kz1000m1 csr "sarge" -next project (just beautification) -07 kawasaki vulcan classic vn900 |
#13 |
reminds me of the battery cables, and washer pump (WHICH STILL ISN'T WORKING)
#14 | |
Bloo
sounds like my "weekend" project.. started out as pack wheel bearings and replace axle u-joints... wound up being replace ball joints, axle u-joints, both axle bearings, clean up galled spindle, 4 new wheel bearings, and new hubs... one of these days, ill leave well-enough alone
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
#15 | |
Engine n00b
If I get it, I am going to have to replace EVERYTHING else underneath it! |
#16 |
fugedaboutit
![]() Join Date: Mar 2005
Dude!! too funny.. I just did the same thing minus the stripped screws- girl and all, when I was done putting the door panel back on I thought.. that looks good but then closed the door and bang
![]() ![]() You have to laugh at crap like that and just keep reminding yourself all the money your saving by doing it yourself.
Currently truckless ![]() |
#17 | |
Out of the carpool lane.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
#18 | |
Engine n00b
#19 |
fugedaboutit
Im sitting here laughing at myself .. this is sad
lol
#20 |
1972 Chevrolet SWB
never fails when your working with a vehicle.
I learned never to tell the wife or girlfriend HOW LONG its going to take when I went to a friends to help or went to the garage to tackle a project. I always say I will be back when its done. I had a brother in law once who had a Pontiac SunBird and needed a starter......he couldnt get the right tools for good access to the starter so he decided to make his job easier by removing the head and then get to the starter..........he had to junk the car afterwards.
My New thread with pics (not my build thread yet.) ![]() http://67-72chevytrucks.com/vboard/s...46#post2573646 1972 Chevrolet 1/2 ton short wide bed,68 frt clip Project. 1980 Camaro Inherited when father passed,68K Miles 2003 Ford Mach1 FUN as Hell!! 2002 Dodge Ram 5-8 slam Rolling BillBoard (Gone not forgot) 2004 Dodge Ram HEMI 10" lifted on 37's and 2wd. |
#21 |
RIP BigDaddyDave ~7-23-09~ You will be missed~
Every truck related project i tackle turns to crap! It sure makes me feel better to know,that others deal with some of the same problems.
BigDaddyDave's Truck: http://www.flickr.com/photos/daves71chevy/ | See it in Action! |
#22 | |
blood type; Retumbo
good thing it wasnt a Caddy northstar. hmm, I see a pattern here. all GM ideas. |
#23 |
![]() Join Date: Aug 2005
I know your pain brother. The doors were the first project I tackled when I got my truck; new regulators, lock cylinders, passenger side vent assembly and rubber all around. I'm sure the neighborhood kids learned a few choice words by the time I was done with all that...
