Old 02-21-2008, 01:10 PM   #1
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Need a lil more info...
Ok guy, I read the FAQ on converting to 6-lug discs using GM stuff
I just have a couple of questions I didn't see answered for definate
#1 can I use any 3/4T lower A-arm from 67-87 (I understand the steering stop differences)
#2 Is there a difference between 3/4T & 1T 67-72 lower A-arms ???
#3 is there a difference between 73-87 3/4T spindles & 88-98 3/4T spindles ???
I have a buddy with some 67-72 1T lower A-arms & want to know if those are the same as the 3/4T, so I could use them for the conversion
I just need to know all my options, cuz I'm limited on 88-98 parts around here
Thanks, Matt
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 02-22-2008, 11:28 AM   #2
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Re: Need a lil more info...
ttt
If I don't get a response, I'll just play guinea pig & find out for myself
Sinister
Killer
Old 02-22-2008, 09:38 PM   #3
crazy longhorn
Fabricate till you "puke"
http://67-72chevytrucks.com/vboard/s...ad.php?t=35042 I think this thread will cover most of your questions
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-23-2008, 02:26 AM   #4
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
I'm pretty sure thats the same one thats in the FAQ
I posted about this a long time ago & just couldn't find my thread, but I think I remembered most of it last night
Thanks for the link
Sinister
Killer
Old 02-25-2008, 12:10 PM   #5
Captainfab
60-66 Nut
Thanks, Matt
I haven't done the swap yet but I plan to, so I will try to answer your questions to the best of my understanding of the thread in the FAQ and my personal research.
#1 to the best of my knowledge, yes
#2 I can't say for sure but I'd say yes. I do know that the 3/4T and 1T lowers are the same from '73-'87
#3 AFAIK yes....the 1/2T and the light duty 3/4T (6 lug) spindles from '88-'98are the same. Also the wheel bearings are the same as the '73-'87 1/2T and the '88-'98 6 lug rotors will physically fit but they won't line up with the caliper.
Hope I've been able to help
