Questionable
Drop spindles + 15" wheels
Quickie, since nobody in the 67-72 forum was able to really answer -
I've heard of clearance issues on certain brands of spindles while running 15" wheels, and the spindles had to be ground down to work. Someone in another thread suggested that this is just a matter of geometry, and can't be avoided. I'm not sure what to think. I figure if anyone knows, you guys would. If it is a matter of geometry, is there a certain amount of drop that will absolutely result in rubbing and, thus, grinding parts of the spindle down? Like, maybe 2" won't rub, but 2.5" will? If any of you 73-87 guys have bagged your trucks with dropped spindles and wheels that are 15" or maybe 16", what brand of spindle did you use, and how many inches were they dropped?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 02-21-2008 at 11:28 PM. |
sold
Re: Drop spindles + 15" wheels
i ran a 3" DJM spindle with 15's on my burb, i had to grind down the caliper a very little bit to make them fit.
07 Rubicon, 2" lift,35's on some bling'n 20"s, warn winch. (20's for sale, 5on5) looking for 73-87 crew cab with 8' bed,2wd,PM me if you see one around |
it's not usually the spindle that has to be ground, it's the brake caliper OR the end of the lower control arm ... but each spindle may be cast differently
as answered in the original post, any time you mix dropped suspension components, small diameter wheels and insufficient back spacing you're gonna have interference troubles ... regardless of manufacturer Last edited by Shane; 02-22-2008 at 01:35 AM. |
Questionable
I'm looking at stock wheels, myself. I believe they're 15", but possibly could be 16". I'll need to measure when I get home.
I was just a bit leery to order a dropped spindle, although that's something I wanted to put in now to prevent disassembly and reinstall later. It might sound lame, I know .. I just like stuff to "fit", I guess.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
67-72 Addict!
shifty- I run 15" rims with 3.75"b.s and McGaughey's drop spindles. I had to buzz the top of the spindle for turning radius and the backside of the bottom to clear my static balanced weights. It takes a few seconds to tap them with a grinder. 16" should clear wheel weights but the tops of McGaugheys spindles have a raised pad that needs to be grinded in the shape of an arc. Again, only takes a few minutes to do. Hope this helps!
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
Questionable
Do they forwarn people about this when you buy them?
If not, any idea why a company would make a part that required to be ground down when used with the stock sized wheels? ![]()
I have BellTech 2.5" dropped spindles and stock 15x6 wheels. The first drop was with cut coils and stock control arms, I never had a clearance problem. With AirRide Strong Arms and dropped spindles I still dont have any clearance problems, laid out or completely raised. The truck is a 84 short bed.
88 Chevy C1500, step side, LS swap. 98 Crew Cab Dually, tow rig. 03 Dodge Neon. ECTA Ohio Mile record holder. |
Questionable
Are you running drums or discs? And do those Belltech spindles work with the stock balljoints, etc?
I have discs. There are two different sizes on the 73-87. A thick rotor and a thinner one. I cant remember the exact measurements offhand. But my truck has the thinner rotors. The thick rotor spindles have a different spud and the lower balljoint is larger. It has been a while since I have ordered spindles so if I'm wrong I'm sure somebody will correct me.
88 Chevy C1500, step side, LS swap. 98 Crew Cab Dually, tow rig. 03 Dodge Neon. ECTA Ohio Mile record holder. Last edited by MotorHead Lon; 02-22-2008 at 04:00 AM. |
My 74: 3" Bell Tech spindles + 1 coil removed from stock springs & 15x6.5" ralleys & stock GM 73~87 1.25" discs.
My 68: 2.5" Western Chassis spindles + 1 coil removed from stock springs & 15x6.5" ralleys & stock GM 73~87 1.25" discs. No cutting or grinding required. About the only tweak needed was the flex-line fitting @ the caliper. It need to be tweaked slightly to ensure the hose didn't contact any metal where routed to the frame. The more BS the wheel has, the sooner there's an interference issue.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 02-22-2008 at 04:35 AM. |
Boosted Member
Ha, I just figured this out the hard way the other night....
2.5" drop McGaughty's spindles, 15x8 AR wheels (not sure on backspacing). When I turned to the lock, I ripped my wheel weights off the inside....LOL. Gotta pull the front wheels, grind some off the lower control arms, and re-balance my wheels ![]()
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
I have an '82 front end with thick rotors on my '63 frame. DJM 3" drop spindles and I have run '71 15x6 steelies and 15x7 Astro Supremes. I didn't have to take any material off the spindles. However, I did have to take a little of the brake caliper.
#13 |
Questionable
I felt like a real dumbass after posting this question, then I forgot to edit.
We're talking about spindles...of course you have discs ![]()
#14 | |||
A guy with a truck
Stock rallies work fine, as long as you don't mind losing your inner wheel weights occasionally. I had some sweet spiral shavings off the inside of some 15" aluminum Centerlines- looked like what you would find on the floor at a machine shop... Quote:
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#15 |
Resistance is Futile
I'll chime in..........I used CPP spindles on my 64 'burb......73 and up suspension upgrade; 1+1/4" discs.........1" springs. I had 15s w/ 4" backspace.........minor rub on one caliper at the top. An 80grit flap disc took it off in 2 seconds........no turning issues.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
#16 |
1972 Chevrolet SWB
Most drop spindles have a recommended wheel diameter to use as a guide but since there are all kinds of wheel offsets,brands,types and such its really tough to cover all bases. I know some companies spindles require 17" or larger wheels and some you have to trim the lower balljoints and such for some diameter rims to fit.
When also comparing a rim of the same width,offset and diameter but using either steel or aluminum is also something to look out for as aluminum wheels will have the inside radius much tighter than a steel rim. In reality the "bolt-on" part of truck or car building just dont happen anymore and if your doing a custom drop,lift,wheels or anything its really up to the installer (you or your mechanic) to make sure all fitaments and such agree with all the components used.
My New thread with pics (not my build thread yet.) ![]() http://67-72chevytrucks.com/vboard/s...46#post2573646 1972 Chevrolet 1/2 ton short wide bed,68 frt clip Project. 1980 Camaro Inherited when father passed,68K Miles 2003 Ford Mach1 FUN as Hell!! 2002 Dodge Ram 5-8 slam Rolling BillBoard (Gone not forgot) 2004 Dodge Ram HEMI 10" lifted on 37's and 2wd. |
#17 |
I have 3" DJM spindles for the 73-87 and had to grind slightly on them. They JUST came in contact with stock 15" steelies. No big deal.
#18 |
I have the 3" belltech drop spindles on my 71' and had to grind anbout a 1/4" off the lower control arm. They used factory balljoints and tierods (which I replaced anyways).
71' Chevrolet -> 350c.i. w/ 600 Edelbrock Carb, Headers, P/S, 3/5 Drop |
#19 |
In the "destructions" from belltech it said you may have to grind the lower control arm.
#20 |
My 71 has thick rotor dropped spindles from Airbagit.com (I know they have a terrible rep) and 2" lowered springs from LMC. Factory 15x8 ralley wheels and no interferance issues at all. Instructions said some clearancing on the lower A-arm might be necessary with 15" wheels but I havn't had that problem. everything clears just fine.
66 Chevy Stepside tandem project My junk: http://67-72chevytrucks.com/vboard/s...d.php?t=480902 |
#21 |
Green club
I run ECE dropped spindles and factory disks on 15 inch rims and have no issues.
I read that there is a difference on some wheels when it comes to the step in the inside. It has to do with one being a drum wheel and one being a disk wheel. this is for factory stamped wheels, but I wonder if some are having issues with this?
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears 70 SS396 Chevelle 427/200-4R/3.73posi 61 Lincoln Continental, black on black Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln |
