![]() Join Date: Feb 2008
Ok, Im bought to buy my parts and just want to make sure Im getting everything I need
Bearings Inner/Outer Seals Rotors Pads Calipers 2x Brake Lines Master Cylinder Booster Proportioning Valve Dropped Spindles Buying a kit would be alot easier, but I have a hook up on parts so buying seperate is ALOT cheaper for me Thanks for any help you may be able to provide to this ROOKIE! |
![]() Join Date: Jul 2006
Re: 67 power disk brake conversion question
Brake fluid.
:-) Looks good other than that. |
You may want to look at a crossmember swap. You can pick up the entire disk brake front crossmember out of a 73-87 truck for less than 100.00 usually. Then it is a bolt on affair. Just a thought.
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
fluid...man good thing you reminded me of that! haha
I have a cross member from a 72, but I let a buddy take some parts off it.... |
