Old 02-22-2008, 04:00 AM   #1
kevinr1970
33 to 31 vs. 3.08 to 3.73
On my ’86 GMC short bed 4x4 I have 33” tires and according to the glove box 3.08 gears. No reason to believe that gears have been changed.
I have a 305 (with headers) and a 700r4.
When driving the truck I can’t help but think the 305/3.08/33 isn’t the optimum combination.
I have a set of 3.73 axles on my parts truck.
I also have talked to a guy that said he would be interested in trading me tires for his 31’s. Tires are in about comparable condition.
What I am wondering is will either one make a bigger difference than the other?
My inclination is to go with the tires as we have a tire machine at work so it would theoretically not cost me anything (maybe a case of beer to the maintenance guy to grease the wheels if you know what I mean). I think that the 31’s would also be the same size as stock or closer anyways. This would get my speedo back right again (or closer).
The 33’s look better though and I think the 3.73’s would give it more “oomph” when driving it. There has been a fairly convincing argument for going with the taller gears as they would put the engine in a better power range at freeway speeds. Also require less effort to get the truck moving from a start. Theoretically netting better MPG; maybe not much but at $3.15 a gallon (and climbing) everything counts.
The 33’s would require more work and probably some money with brake fluid for bleeding the brakes. The front brakes on the parts truck need to be done too so turning the rotors and new pads, etc.
Also, not only is the speedo off because of the tires, but not sure how it would be affected by the gear change too?
Any thoughts?
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 02-22-2008, 05:18 AM   #2
Prerunner1982
Prerunner1982's Avatar
Re: 33 to 31 vs. 3.08 to 3.73
Go with the new axles. The 700R4 has a decent 1st gear so the lower gears would certainly give you a better start. My 32"s with 3.08s were a pain to get going and I think i only got abotu 8-10mpg around town because of this, with a th350 trans.
As far as ease... The tires would be the best route.
As far as getting the speedo close, changing the gear ratio could do the same thing. I dont have the chart infront of me to see exactly what gear ratio closest to the origial ratio but I am sure someone will pop in with it.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 02-22-2008, 05:23 AM   #3
duallyjams
duallyjams's Avatar
My vote goes for the 3:73
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 02-22-2008, 10:42 AM   #4
Texasdeere
Texasdeere's Avatar
3.42 gears are about as tall as you want to go with a small block TH700 combo. 3.73 are a good match for a SB/TH700
Here is a gear calculator for you to plug in some diff tire & rear end combos to check RPM:
http://www.xse.com/leres/bin/gearrat...mference=91.11
Texasdeere is offline   Reply With Quote
