Old 02-22-2008, 04:48 AM   #1
Jvan
Question 67-68 grill on a 72 Blazer.
I'm still in the planning stages for my restoration of a 72 Blazer. The front grill, bumper, radiator support, headlight surrounds, grill trim piece and hood are all in excellant shape. Both fenders and inner fenders need to be replaced. I really prefef the early grill w/the horizontal bar to the open grill of the 72. Can I just replace the grills using a 67 grill support bracket and keep the 72 hood/fenders, headlights? i know the 72 has the lights in the bumper which I may use to hold fog lights or I may just do a front roll pan. I would use the signal/parking lights from the 67-68. Is this doable at a reasonable cost since anything is doable at a price.
Jvan is offline   Reply With Quote
Old 02-22-2008, 05:56 AM   #2
lks dcvn
lks dcvn's Avatar
Re: 67-68 grill on a 72 Blazer.
You asked - "Can I just replace the grills using a 67 grill support bracket and keep the 72 hood/fenders, headlights?"
No - not as easy as that...
You will need...
67/68 grill
67/68 grill support
67/68 hood
67/68 hood release
67/68 radiator support
67/68 fenders - 67 doesn't have turn signals holes, 68 does
If you can find a complete front clip to swap on - it is much easier...(and usually cheaper)
You can use the lights in the 67/68 grill if you wire them up - the use the same wiring as the 72 signal lights (I would assume).
So yes - it is doable - just need a few more things for your swap...
Hope that helps!
lks dcvn is offline   Reply With Quote
Old 02-22-2008, 06:27 AM   #3
jaros44sr
jaros44sr's Avatar
How about a '67-'68 on a '72 Jimmy
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 02-23-2008, 08:23 AM   #4
Jvan
Thanks for the list. I was hoping that the 72 hood would not have to be replaced because finding one here in NY is not likely and shipping would be prohibitive. I was hoping the same for the front fenders since I have already picked up a good pair. Aforum member has offered to sell me the grill support and hood release so I have that covered. Maybe I'll just restore the front to original 72 while I look for the remaining front parts to change to 67-68. Atleast now I know what I need to gather.
Old 02-23-2008, 05:30 PM   #5
vtblazer
vtblazer's Avatar
How far gone is your current front clip?
What's it need?
vtblazer is offline   Reply With Quote
Old 02-23-2008, 11:26 PM   #6
hgs_notes
GEARHEAD
hgs_notes's Avatar
Don't mean to threadjack ya, but I want to see a full shot of this one. If you can make it work right, that would be an original idea (so few of them now). I don't think I've ever heard of it, but looks promising.
hgs_notes is offline   Reply With Quote
Old 02-24-2008, 01:22 AM   #7
jaros44sr
jaros44sr's Avatar
Let me see if I can link ya to my other thread, VT Blazer gave me directions on how to doit, but it mite take awhile. Here is one more pic, then I won't bother this guy anymore
SAFETY FIRST
AS usual, off topic
Jim
Old 02-24-2008, 01:36 AM   #8
jaros44sr
jaros44sr's Avatar
Try this link, sorry for the double post but I couldn't tie it to #7, no room I guess
http://67-72chevytrucks.com/vboard/s...84#post2572584
Cool it worked, Kurt really knows his stuff. I'll be updating it within the next week as I just got ahold of the grille inserts and headlite bezels.
Thanks for your interest...J.
Hyjack off
SAFETY FIRST
AS usual, off topic
Jim
Old 02-24-2008, 02:42 AM   #9
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
My 71 GMC Jimmy "Merlot" has the conversion, and so will "GQ" once the 2wd frame gets here from FL
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 02-24-2008, 07:15 AM   #10
Jvan
Question Re: 67-68 grill on a 72 Blazer.
My front clip is really in good shape. The bumper, grill, lights, outer moulding, hood, radiator support are all in good shape. I only need to replace the inner and outer fenders. I was hoping that my hood could be used with the 67-68 grill. Why do the 72 fenders need to be changed except for the side lights? What are the differences between the 67-68 fron and the 72 except for the obvious grill/bumper/headlights?
Old 02-24-2008, 07:28 AM   #11
jaros44sr
jaros44sr's Avatar
That's why I showed you mine, it is all '72 except the grille. If you modify the headlite bucket mounts in the rad. core support, you can even stay with your '72 core support.
SAFETY FIRST
AS usual, off topic
Jim
Old 03-06-2008, 06:51 AM   #12
Jvan
I've been away for awhile and haven't checked the thread. Thanks for your encouraging thread on your build. I don't have the skill to try to follow your lead. But I haven't given up the idea. I'll study your build and see how much I have to modify the headlight area in the radiator support. Your work is great.
Old 03-06-2008, 05:00 PM   #13
jaros44sr
jaros44sr's Avatar
It's not hard, you can do it with a rivet gun if you don't have a welder. One cut across the '67 grille, mite work for'69-'72 chevys as well. Drill out spot welds on your headlite bucket, drill two square holes and a hole for the spring
I was lucky and got a '67 core support, made it easier
SAFETY FIRST
AS usual, off topic
Jim
