Old 02-22-2008, 07:29 AM   #1
rscam
Third gen. Camaro cluster in 67-72 Truck
I'm new but I thought I would throw out this question. I see many people on the board talk about gauges but I haven't see much more than just different variations of what is already in the truck. I have taken a cluster from an 85 IROC and held it in the hole for the cluster. It fits really good and it has a tach and actual gauges instead of idiot lights. If I try this what problems would I encounter? It is pre 88 so it will have a mechanical speedo. So I think all the gauges would be as simple as tracing the wires to each gauges(volts, oil pressure, fuel etc.) Please let me know your input. Thanks in advance.
rscam is offline   Reply With Quote
Old 02-22-2008, 07:35 AM   #2
67_C-30
I have a radical idea!
67_C-30's Avatar
Re: Third gen. Camaro cluster in 67-72 Truck
Welcome to the board!
It should work out fine if you can trace all the wiring. Does your IROC cluster have the 145 MPH speedo?
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 02-22-2008, 07:43 AM   #3
67_C-30
67_C-30's Avatar
BTW, Here's the gauges in my '82 Z28 street/strip car. I put an IROC cluster in it with the 145 speedo. I have templates for all the white gauges if you want them. It printed them on glossy decal paper, and they have held up great for about 8 years now.
My trucks
Old 02-22-2008, 07:57 AM   #4
rscam
I don't actually have an IROC cluster. I just borrowed one to see if it would work. I don't nee a 145 mph speedo any way. I'll probably just get a 115 mph cluster. If you look at the pic in the last post I am goinh to try and use the 2 sides of the gauges also. The pieces that stick out and hold the headlight switch and cig. lighter. I also thought about the whole dash but I think it woud be to thick and stick out past the dash. Also I am trying abunch of different things. I am putting an overhead console in from a 96 Suburban. I have mounted 70 Camaro lights in the rear fenders but only the half that dosent have the reverse lights in them. I am also int he process of putting an NV3500 in it now and converting it to a side mount spare. I have a console from a Dodge Neon that has drink holders in it. It fits perfect up to the heater box. I have a tilt column out of a 70's Chevy van to boot.
Old 02-22-2008, 08:01 AM   #5
screamin_c10
I dun gradjiated collij!!!
screamin_c10's Avatar
screamin_c10 is offline   Reply With Quote
Old 02-23-2008, 03:48 PM   #6
derek6787
Backwoods Body
Not necessarily a good one but just an idea. I saw a 67 chevy pickup with a complete dash out of a 88-94 chevy in it. Kinda ruined the inside of the truck for me but looked like it fit nicely and if you're wanting to upgrade with something newer there's an idea for ya.
derek6787 is offline   Reply With Quote
