Old 02-22-2008, 09:30 AM   #1
skokie
skokie's Avatar
Horn problem part 2
Ok part 1 is here http://67-72chevytrucks.com/vboard/s...d.php?t=278525 which I thought was a bad horn from my truck. Well I got a new one and same thing. I plug in the horn and it just goes click coming from the horn relay. I have a new horn relay that I was going to install later and it did the same thing. Steering wheel is a grant 967 and I have the correct kit. If anyone has any ideas on how I can get this horn to work then post away.
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 02-22-2008, 10:31 AM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Horn problem part 2
Had the same problem. I took the horn out to check it. I rigged it to wire it directly to the battery. Your horn should have just one connector. The bolt on the mount to the frame should be the ground. I sanded it down real good and placed a wire on the ground side and clamped it to the neg. terminal. Then I touched the other wire to + side of the battery...
At the time I did this, I did not have my meter with me so I couldn't check to see if I was actually getting voltage to the horn itself.
Found out my horn was bad. Had to buy new one.
68gmsee is offline   Reply With Quote
Old 02-22-2008, 10:43 AM   #3
68gmsee
Active Member
68gmsee's Avatar
Oh, forgot to mention... The new horn was also defective. I wound up having to get one from NAPA.. Happened many years ago, so don't remember the brand.
Old 02-23-2008, 04:03 AM   #4
skokie
skokie's Avatar
Ill try that test with the battery to test the horn.
68 build thread
Old 02-23-2008, 04:23 AM   #5
neonlarry
neonlarry's Avatar
If the relay is clicking your horn button sounds like it is working, if the horn works hooking it directly to the battery I would check and see if your have 12V in the power wire to the relay.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
