How much can a 67 C10 pull safely?
I know they are a 1/2 ton pickup but wont coil springs on a 41 year old truck but weaker than a new 1/2 Chevy? Thats why I just don't know what I can do with it. I will start working on my 67 in the next week or so. So far this pickup hasn't change for 12 years and its time. I have a '01 Dodge Dakota cc with a 408 stroker and I would just love to pull it to the races with my old Chevy. What would people think about a old beater Chevy pulling a pretty new Dakota? Anyways, I will be putting it on a 16ft trailer and the truck itself is about 4500lbs and its with a 4.7v8 when it was new so its still right at that same weight. I know the engine will pull it with no problems but the truck is a different story. If it wont hold up, is there anything I can do to make it? air bags to help keep it level? or maybe if I can convert it to leaf springs? I'm not sure but I thought the 1 tons or 3/4 tons may have had leaf springs under them. Any help would be great because I'm lost.
#2 | |
Re: How much can a 67 C10 pull safely?
Upgrade to the largest front discs you can afford, get good trailer brakes (both axles if you can afford it), & either swap bags in place of the rear coils or use helper bags designed to fit inside of rear coils for added lift when needed to level the truck.
Its good to hear that a 41 year old truck has still got it in it to get the job done. I looked into the bags that go inside the coils to help keep the truck level and the shop I went to said they come for specific models and installations and I can't get any for a 67. I do know that my dakota pulled better when it was 3/5 dropped because it hit the bumpstops and that kept it lever..lol. What is done to your 68, is it a 1/2 ton? I want to lower mine, probably 3/5 and I can upgrade brakes because right now I'm not even power brakes yet. When I was 17 and drove it only the back brakes worked, on a good day, a bad day and only 1 back worked. Yea, it would slide a little when you had to slam on the brakes, the good ole days when you didn't care about anything but maybe should have. Thanks for the news that my truck can do it.
Definitely swap to power discs.
There's several companies that make bags that are a direct swap for the rear coils. That's how mine was done. 2 bags w/separate DOT airlines routed to 2 schrader valves hidden behind the rear ECE flip-up license plate (it's part of their hidden-hitch kit). When I towed stuff before, I was still using the original 250-6 3spd combo as well w/no problem. Now it has a 350/700R4 but isn't back on the road just yet.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 02-23-2008 at 01:36 AM. |
///Relaxed Atmosphere
I pull a 30ft travel trailer with my 72 sub and it does fine. I have air ride and 20's. I have a trailer brakes load sharing hitch with sway control and it moves on down the road just fine. Gas milage isn't the greatest, but is does the job. Total weith is about 5000 lbs loaded
here is a pic on my way to Good Guys Dallas last year.
72 Suburban 64 Chevy short fleet 04 Chevy Colorado Sport Reg Cab 2012 Chevy Avalanche 2003 Chevy S10 Blazer Xtreme http://www.hubgarage.com/mygarage/RA_Jeff 64 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=295915 |
![]() that is a nice a setup........ o.k. i'm done high jacking my small .02 i have applied the helper spring kits to some vehicles and it helps out a lot. the new Hitch helpers are great, i have also seen a lot of them popping up at the track, mud runs etc. etc. and have heard nothing but good stuff about them.
Lug Nuts Classic Rides. (Bodywork, small fab, and Restorations) Perry, Ok. We're just two guys, trying our best. 72 cheyenne super https://67-72chevytrucks.com/vboard/...d.php?t=811512 55 chevy truck http://67-72chevytrucks.com/vboard/s...d.php?t=840174 |
As others have touched on you're asking the wrong question. I can pull your Dodge with my Ford Escort. I just won't be able to stop it when I need to.
Disc brakes up front for sure. Electric brakes on the trailer.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
Oh, lol, I have disk brakes. Ok, here's the right question for this, I have a 67 chevy swb 1/2 ton. How can I get this truck to stay pretty level? I'd love to see pics of anyones truck to see how it holds up to a good size load, and underneath pic of whats done to it. It would help a lot if someone could point me in the right direction at a place where I can buy it and what I need to buy. I'm going to load my '07 JK on a trailer tomorrow and just see how low it sags, but I'd bet on the rearend hitting the frame...lol. 1 more quick question guys, if I have 4.11's and have a roundabout 400hp in a 350 maybe a bit more, well when I get my buildup Bowtie heads on. I'm getting higher gears because gas mileage is 10mpg...lol...I want to go 3.42's. What gears are you guys pulling with? I may stay 4.11.
I have a radical idea!
With the big cam, 11:1 pistons, Holley 750 and I'm assuming high rise intake you have on that engine, it is not going to be ideal for pulling. You'd be better off going with camshaft profile that makes power down low. I speak from experience when I say this. I attempted to use a hot rod as tow rig years ago, and that was when gas was 89 cents/gallon!! I'd hate to imagine would it would cost to feed today's gas prices.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
#10 | |
![]() Join Date: Apr 2005
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
I am a Referee of life.
67 C-30 hit the nail on the head.HP wont pull your trailer torque will.If you have a cam with a RPM range tthat is fairly high,you will need to spin the engine in that range to get enough power to pull.The 4:11's may be better unless you recam.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Here's my tow package boat and trailer weigh 6000 lbs plus I load the truck with camping gear. I have power disc on front and a one ton rear with large drum brakes. Duel axle surge brakes on the trailer. Truck has plenty of power and gets about 10 mpg towing the boat with 4:09 gears and a turbo 400 trans.
69 Chevy 4x4 383 Power ![]() |
#13 |
Thanks for the help guys. I have a tread about getting gas mileage up some because I'm about 10mpg now. Yes when gas was 80 something cents it was now big deal...lol. I will be going to a 3.42 gear, maybe, a smaller cam, smaller carb, and duelplan intake, Edlebrock performer RPM. I am open for any tips on getting this thing to pull a load every now and again. This truck only knows hotrod and spinning tires, its a retired street/hot rod and retired 700hp+ 468 with 400hp shot of nitrous. I need to teach it something else in it 41 year life which half was probably spent in a feild rusting.
#14 | |
p.s. Like that matching paint, if I had a boat and that truck that would be me...lol. I'm a guy and sometimes I can't match my clothes right but I can match things on my toys...lol. Last edited by The Big Green; 02-23-2008 at 08:35 AM. |
#15 |
Rebuild the stock coil setup so its in top shape and keep it...........Honestly IMO, the coil setup is way better than leaves. They handle the weight alot better and will take being overloaded overwhelmingly better than the leaf setup. Only trouble is with the age, they can be a bit sloppy and it effects driveability towing, a quick refreshing of the bushings cures it.
We had acouple C-10's for farm trucks, one we ran over a decade in that use, it sold me on coils. I never seen a truck that was overloaded and abused more than that old green C-10 and it just kept going. I'd put that old truck up against any new 1/2 ton from the big 3 and yota. The biggest trouble I see with a C-10 towing is staying legal with weight limits.........Because they were underated IMO and it isn't hard to exceed the rating, although they don't flinch at the weight in reality.
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck '71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel! '69 3500 GMC 305V-6/4spd, Still under reconstruction.......... Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!! |
#16 |
I'd like to keep the coils and not mess with anything. The coils are 41 years old so they could be a little sloppy...lol.
#17 | |
#18 | |
