02-23-2008, 03:37 AM | #1 |
Door speakers
So I looked and looked and found nothing about fiberglassing or creating some sort of inclosure within the door so you can get a waterproof and air tight proof inclosure. I was wondering if anyone has tried this or seen someone do it. Its difficult because of the lack of room within the door, but I am pretty sure something can be made.
My doors were already cut up so running a pod is not an option because I am just going to make use with what I have. Suggestions I highly appreciated!!!!!
Chillin |
02-23-2008, 03:40 AM | #2 |
Re: Door speakers
I know some jeep guys use plastic containers (like cool whip, tuppaware, etc) and glue them on the inside door area to enclose the back side of the speaker.
Maybe that could work for you. Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
02-23-2008, 03:43 AM | #3 |
Re: Door speakers
I have that exact same set up on my truck. Running 6X9s in the doors. It was done by the previous owner. He didn't do a very good job and now the bottom of the door is shot from rust and the speakers don't work from water damage. I would suggest finding some way to waterproof the speaker and get new seals and felt for the window.
Mike 68 C10 LWB midnight blue metallic 307ci, 700R4, HEI front discs, leaf spring rear tilt steering wheel, stock ride height, rally wheels, 2007 Dodge Charger(Hemi) |
02-23-2008, 03:43 AM | #4 | |
Re: Door speakers
Chillin |
02-23-2008, 03:46 AM | #5 | |
Re: Door speakers
Chillin |
02-23-2008, 03:50 AM | #6 |
its all about the +6 inches
Re: Door speakers
I put poly speakers in my doors so they wouldn't be too effected by the water.
02-23-2008, 03:57 AM | #7 |
Re: Door speakers
Waterproof foam baffles keep your speakers clean and dry, and improve your bass response. They compress easily to fit behind your speakers.
XTC 4x6-inch pair Slim Speaker Baffles XTC 4x6-inch pair Speaker Baffles they're like 8 bucks at crutchfield Last edited by David Flores; 02-23-2008 at 03:57 AM. |
02-23-2008, 03:58 AM | #8 |
Son of a gun
Re: Door speakers
Felts and weather stripping won't keep water out of your door, water is supposed to drain out the bottom.
The problem happens when the drain holes become clogged with rust and junk.
Bill BEATERS ARE NEATER |
02-23-2008, 04:03 AM | #9 |
Re: Door speakers
Also you may consider marine speakers. i don't know how good they may be, but I figure by now there should be good boat speakers out there.
Shawn
02-23-2008, 04:29 AM | #10 |
Re: Door speakers
Here is what david is talking about, these are what I used:
http://www.crutchfield.com/App/Produ...x?g=762&tp=660
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
02-23-2008, 06:16 AM | #11 |
Re: Door speakers
DavidFlores and Neonlarry thanks for the input.....I searched around and those things are pretty cheap in price....How do they withstand for air tight ness?
thanks for the input I am gonna hit a local flea market in the morning cause I heard they have them there as well.
Chillin |
02-23-2008, 03:29 PM | #12 |
Backwoods Body
Re: Door speakers
I'm in on the marine speaker idea also. I had marine 6x9's in my jeep wrangler that rarely had a top on it and they held up very nicely and the sound quality was just as good as normal ones. The only downside is they are quite a bit more expensive.
02-23-2008, 05:06 PM | #13 |
Old member
Re: Door speakers
Look into the speaker backing cups. They are soft rubbery foam made for this. I have a pair that I took out of my 71. They just screw on the back when you install the speaker screws.
I can't say if this is the right term or not.
02-23-2008, 11:43 PM | #14 |
Re: Door speakers
The marine speakers was an idea but the problem is I already have a brand new set of speakers so buying another set is not going to fly, but thanks for the input.
The baffles are what I think I am going to lean towards. I heard they have them at a local pepboys, so today I will go on the hunt for them. I ran the homedepot yesterday and bought ducting insulation that is about 1/8" thick and has self adhesive on it, I want this to insulated the door some since they sound so hollow. and I also found a utility belt.......yes I bought a utility belt just because it was clearance out for 3 bucks....LOL thought I would share that with you guys. Anyhow. I will be posting pics, I am hoping to have them in by tonight sometime. Thanks again to all!
Chillin |
02-23-2008, 11:51 PM | #15 |
STOLEN
Re: Door speakers
You could always buy ABS sheet plastic and fabricate a box. It's pretty thin, rigid, and proper glueing creates a water tight seal.
In Search Of |
02-24-2008, 12:37 AM | #16 |
Engine n00b
Re: Door speakers
I had a 70 dodge and cut the doors for 6x9's.
never again. rust, water, ruined speakers, and rattles never got fixed. I would rather do a headliner set of nice 6.5 rounds and a sub where the gas tank was (well, is currently) |
02-26-2008, 08:27 AM | #17 |
Re: Door speakers
So this is where I am at now......NOT DONE! I started on the doors and ended up realizing more work was needed....the doors had been drilled out from panels that were on the bottom, so the welder came out and away I went. I have to get some filler out to level things out but the weather is not right at the moment. So I started working on metal panels that I decided to go with. Some primer, paint, and clear coat and the panels were back in business.
The baffles are gonna work great and the insulation is gonna fit nicely in the doors. I will keep the pics coming to show the finsihing touch!
Chillin |
