02-23-2008, 08:04 AM | #1 |
12 bolt limited slip posi, is it factory?
So over the summer i jacked up my rear end to see if I had a posi without taking off the rear end cover. I spun the wheels and they spun in the opisit direction.So seeing that i presumed i had no posi, just peg leg. Today I pulled off the cover and found a limited slip posi ( not the clutch posi, the spring one) sitining in there. Now the question is, is the limited slip factory? The rear end gears are 3.08's. I read unless stated on the options list that factory atomatic trucks are 3.08 gears and 3 and 4 speeds are 3.73 gears. Am I right? My truck was a factory atomatic truck so the gears are right but is the limited slip? There is no indication on the option list of it. If not where did it come from? Thanks
02-23-2008, 09:39 AM | #2 |
Re: 12 bolt limited slip posi, is it factory?
It may be factory,but if it was original to the truck the option would be listed.
02-23-2008, 11:12 AM | #3 |
Dave's not here, man
My truck is an automatic too, but it has 3.73's. The trans. was special order (Powerglide), so I'm not sure if that has anything to do with it or not.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 Last edited by dave2953; 02-24-2008 at 04:38 AM. |
02-23-2008, 12:13 PM | #4 |
I just recently replaced my gasket and cleaned things up. I don't know about the automatic, but mine's a manual and it came from the factory with a 3.07 posi. There should be an axle code stamped on top of the axle, passenger side. This thread has a picture and a link to decode it:
http://67-72chevytrucks.com/vboard/s...ight=axle+code That should tell you what you have, unless of course somebody has changed it out. What year is your truck?
--------------------------------------------------------- I'm not crazy, I'm chosen, there's a difference. ---------------------------- '72 K10 SWB, 350, sm465/np205 ---- ---- |
02-23-2008, 12:17 PM | #5 |
Here's the recent cleanup ...
02-23-2008, 12:29 PM | #6 |
its all about the +6 inches
4 speeds got 3.07 as did hydromatic trucks... I think the glide got 3.73, but I'm not certian.
02-23-2008, 12:31 PM | #7 |
What did you use to clean it up and paint it?
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
02-23-2008, 12:48 PM | #8 |
I was actually surprised at the lack of rust (very little) on the front side of the diff. I guess the 1/2 inch of oil and road grime was a good protectant! I sanded the cover and used a degreasing gel on the rest. Used brake cleaner on the inside. Primered and sprayed.
02-23-2008, 01:06 PM | #9 | |
in 68, the option listing for M49 (TH400... since there was no Th350 yet); Turbo Hydramatic; includes HD radiator, includes 3.07 rear axle gear when ordered with 327 or 396 engine. So, your truck was either a 250, 292, or a 307 powered truck originally. I made it ALMOST all day without learning anything... you ruined it for me! |
02-24-2008, 01:10 AM | #10 |
My truck is a 72
02-24-2008, 01:21 AM | #11 |
So get a flashlight and a wire brush and take a look on the top part of the axle tube, passenger side of the differential, should be a stamped code. Post them here and I'll decode, or go here:
http://www.americanclassic.com/paint_test.asp
02-24-2008, 03:54 AM | #12 |
my 72 gmc has a factory limited slip with 350 and th 350 tranny. all listed on the spid. i'll get a pic.
Ooops I was wrong its factory posi.
72 LWB Last edited by 2nd_wnd; 02-24-2008 at 04:02 AM. Reason: added photo |
02-24-2008, 04:35 AM | #13 |
I believe posi or limited slip is the same thing.
Funny how the spid listings can differ, mine doesn't show the rear ratio. What the hell is G78-15-8 HIGHWAY B8 ??
02-24-2008, 04:42 AM | #14 |
I believe that's referring to the tires that came factory, which were bias ply.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
02-24-2008, 06:19 AM | #15 |
BlahBlahBlah
On my 71 4x4 it says it has a G86 no spin rear axle on the spid. Whats the difference between that and a posi, or is it the same thing?
02-24-2008, 09:07 PM | #16 |
k i'll check that code out on mon
02-24-2008, 10:57 PM | #17 | |||
02-24-2008, 11:59 PM | #18 |
BlahBlahBlah
Thanks for that info LONGHAIR now I have to look that up and see what it is =) It makes a clunk now and then back there.
