Size Matters
Opinions, notes, comments etc. on headers
OK I know a lot of you have installed headers and I know the principals about why they are better. What I want to know is how much better have you witnessed and in what way? Better power obviously but is it like night and day just from switching to headers? How about fuel economy? Like I said, I understand the principals but I have never actually done it and I know you have so gimme the benefit of your experience please.
"Reading the owners manual is only for quitters." Jason Harper, Bloomberg News. ![]() ![]() |
#2 | |
Bloo
Re: Opinions, notes, comments etc. on headers
on my 89, which is the only truck ive drove extensivly with manifolds and headers, the headers made it WORSE. lost 2 mpg, no low end power, ran lean... they're also a PAIN to get to some spark plugs.. get them to close to the floor, and it'll be nice and toasty too..
can ya tell i dont like headers anymore??? ![]() edit: i didnt think about it, but i have ran the 69 with two different sets of headers.. one set of 3/4 length large tube, and one set of full length small tube. the full/small tube headers had more low end, the large 3/4 ones had more top end
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
![]() Last edited by Blue_71; 02-23-2008 at 12:54 PM. |
back in high school we installed headers on my buddys 69 camaro 307. We went from manifolds and single exhaust to headers, short pipes and two mufflers, it was a night and day difference and it was hard to believe it was the same motor.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners. Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=219094 Last edited by whatnow123; 02-23-2008 at 06:07 PM. |
Active Member
The most common mistake with headers is going to large tube style headers.
As a general rule street driven trucks need smaller dia tubes to maintain the scavenger effect. This may change if you have a mountain motor. Spend the money and buy a pair of ceramic coated headers, they will look and work much nicer than painted headers. If you choose the correct size you should see an increase in performance, gas mileage, and cool factor.
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles ![]() 18.5" x 31" Hoosier Pro Street Radials ![]() ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree ![]() |
Fabricate till you "puke"
The longtube headers I have run have always been an improvement over stock exhaust. on a street driven sb, I like to run an 1 5/8 primary tube(327-383), maybe drop down to a 1 1/2" tube (283-307) for best tork. The 406 can probably run a 1 3/4" tube without any loss in low end grunt. You will notice bigger gains on a hopped up motor, than you will on a stocker tho. Also watch the ex pipe sizing 2 1/4" dual is plenty for a mild 350, where you are better off with a 2 " pipe on the smaller cube motors. An H or X pipe in the system will also help with low end tork/mileage. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
#6 | |
high-Tech Red Neck
Really I think putting anything larger than that on a small block in a street truck is just silly.
"He used to be a pretty nice feller, now he's a welder!" |
Size Matters
Thanks guys. Good advice so far...keep it coming. The more people I hear from the better.
This is all good advice. What are your opinions on running headers with a 2.5" collector vs. a 3" collector and then using a reducer to go to 2.5" pipes?
1970 C10 - ECE 3.5/5 drop, dual exhaust with turbo mufflers, front discs http://67-72chevytrucks.com/vboard/s...d.php?t=272458 2000 Buick Regal GS - Supercharged 3.8 V6 240hp, 1/4 mile 15 seconds |
I have a radical idea!
The header brand and construction you choose is very important if you want a leak-free set-up. A cheap header with stamped thin flanges are going to leak - sooner usually than later. A good brand 16 gauge header with thick flanges with the ball socket type collectors are the best way to go, but you pay for what you get. As crazy longhorn said, the gains on a stock engine are far less significant that on a stock engine a modified one. You won't a night and day improvement with just a header change.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
