Old 02-23-2008, 05:31 PM   #1
larry may
Smile Exhaust Question
Am using 2-1/2 inch SANDERSON stainless ram horn headers. Would like to use stainless pipe and stainles turbo mufllers and stainless pipe all the way to the bumper.
This is a 68 short step with a fuel tank under the bed directly behind the differential. I have modified the x member by making a 4 inch hole on the left and right side of the x member so the exhaust can stay close to the underneath floor. This step side also has trailing arms.
My question is there a jobber out there somewhere that would have an exhaust system that could be bolted in or welded in that is preformed for installation. Last job I had done at a muffler shop was a Hacked up pos job and looked like a well it just was not very neat.Pipes rubbed the shocks hit a bump or low place the trailing arms woul pinch the pipe upward toward the frame. Really made my A$$ tired when I would think about the dip wad that did the work, Thanks for any help from you wizzards. Larry
The biggest problem people have, is other people
Thou shalt be cool and not hassle
Be a site supporter.
The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2
larry may is offline   Reply With Quote
Old 02-23-2008, 05:43 PM   #2
Slammed N Ratty 69
Re: Exhaust Question
There is a kit by magnaflow for these trucks, it is all mandrel bent stainless with an x pipe. usually they fit pretty good but might require a little tweaking to get them to fit.
Slammed N Ratty 69 is offline   Reply With Quote
Old 02-23-2008, 07:53 PM   #3
larry may
Well alrighty then Slammed : this information is what I was hoping for and thinking about. Perfect in everyway. Thank You . Larry
