Old 02-23-2008, 09:35 PM   #1
chrislehr
Engine n00b
chrislehr's Avatar
ECE drop kits standard versus premium
Tell me why I want to relocate the shocks and a panhard bar for $120
Not questioning the value - just don't know the purpose.
chrislehr is offline   Reply With Quote
Old 02-23-2008, 10:01 PM   #2
Andy4639
Old member
Andy4639's Avatar
Re: ECE drop kits standard versus premium
Once you lower the truck the shock are on a worse angle and don't move up and down but instead they try and roll on the two mounting studs. They don't have enough travel in the shock to let the truck move without bottoming out. This makes the ride not so nice.
The track bar is the same way it's length is to long for the drop so it pushes the truck off to the side and makes for a bad ride.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 02-23-2008, 10:12 PM   #3
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
If you drop your rear suspension just a couple of inches, it shouldn't be a problem. ECE recommends that you use the shock relocators if you drop it 4-inches or more. It re-establishes a proper angle of operation for the shocks, which would otherwise be useless if you don't relocate them.
As to the adjustable panhard rod, you don't have to use it if you lower it more than 4-inches in the back, but you will find that your rear axle is going to be off-set to one side. The adjustable track bar lets you center the rear end under the chassis. You could alter your stock panhard rod, if you wanted to do so.
I have the shock relocators and the adjustable track bar under my '69, which is lowered 4-inches in the back. The ride is outstanding.
ECE's website and their free catalog will explain why they make their suggestions. They also have excellent technical help, and have saved me some money (costing them the same) by suggestion other sources.
Member Nr. 2770
Old 02-23-2008, 10:21 PM   #4
Ole Blue 68
Ole Blue 68's Avatar
I went with the premium kit and have been very happy with the results. My 68 rides like a new truck.
Ole Blue 68 is offline   Reply With Quote
Old 02-23-2008, 10:24 PM   #5
chrislehr
Engine n00b
chrislehr's Avatar
Awesome. Thanks all who responded...
I dont have a problem with the 120 more (especially when shocks+springs (non KYB)) are the same price on LMC as the premium on ECE.
THANKS!!!
Old 02-23-2008, 10:48 PM   #6
chrislehr
Engine n00b
chrislehr's Avatar
90 dollars shipping?!?! WTH?!
Old 02-23-2008, 10:51 PM   #7
chrislehr
Engine n00b
chrislehr's Avatar
still ordered, but that hurts.
Old 02-23-2008, 11:54 PM   #8
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Did you call and place your order? Sometimes they are able to cut a better deal than they website lists. ECE has quality products that you will not regret the extra money. Be sure to post pics...
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 02-24-2008, 12:26 AM   #9
chrislehr
Engine n00b
chrislehr's Avatar
Nah - I spend all day avoiding the phone... Ill just do the pricing online for now.. maybe the next order (spindles and brake conversions) I will ask for a deal.
Old 02-24-2008, 12:50 AM   #10
RCbowtie69
RCbowtie69's Avatar
i brought the ECE kit, drop spindles, shocks, sway bar for lower trucks, adjustable panhard bar, front & rear coil springs 1in.front, 4in in back, love the tech help me.they were very helpful
RCbowtie69 is offline   Reply With Quote
Old 02-24-2008, 01:02 AM   #11
Ole Blue 68
Damn! I paid $40 last year to Houston. I'm sure prices have gone up but double?
Old 02-24-2008, 01:39 AM   #12
chrislehr
Engine n00b
chrislehr's Avatar
I hit 1-3 day shipping, and it was $250.
After I collected my jaw, I went with the 5-7 day
