Old 02-24-2008, 03:40 AM   #1
kevinr1970
Another tach cluster question
A guy locally advertised a tach cluster from he says an '82 truck. From my searching of threads here and 73-87.com it seems that after '80 info gets a little sparse.
If the cluster is from a 6 cyl. truck will it just not work (calibrated wrong) or can you do something to "fix" it to work for an 8 cyl.?
In the ad it says that a few of the mounting tabs are broken but shouldn't be a problem. If the housing (the blue part) has broken mounting tabs can you pull the guts and circut board(?) from the cluster and re-install them in a good housing?
Or is this a lost cause?
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 02-24-2008, 04:11 AM   #2
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Re: Another tach cluster question
If your using a nontach housing to mount the tach into then you will need to cut a small opening into the bak of the housing for the terminal housing/ tach mount to protrude thru the back.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
