02-24-2008, 03:56 AM | #1 |
Alingment Specs. for 47 to 54 Chevy
I am looking for alingment specs. on a Mll front suspension on my 55 1st series G M C.
The ware has caused the outside tread on the tire to ware down to replacement time and I want to correct the problem by placing new tires and alingment. My thoughts are a positive camber or a toe in problem, Is there a general spec for all Mll's or should there be some compensation for this ware pattern because of the weight of the truck Vs. the Mll
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
02-25-2008, 01:04 PM | #2 |
1972 Chevrolet SWB
Re: Alingment Specs. for 47 to 54 Chevy
here are some general specs to shoot for if in doubt
0.00 camber right and left vary -0.2 per side if needed 3.50 caster left 4.00 caster right always run more caster by .50 degree on right vs left toe in +0.05 per side for =0.10 total toe in. I always try for either dead zero camber per side or slight negative. Excess neg or positive toe in or out will wear inside or outside edges quicker than some neg or positive camber will. I always shoot for positive caster for better steering and with 1/2 degree more on the right than the left will compensate for road crown drift. toe in by 1/8th inch is general rule but I try for at least +0.10 total toe in for best results.
My New thread with pics (not my build thread yet.) http://67-72chevytrucks.com/vboard/s...46#post2573646 1972 Chevrolet 1/2 ton short wide bed,68 frt clip Project. 1980 Camaro Inherited when father passed,68K Miles 2003 Ford Mach1 FUN as Hell!! 2002 Dodge Ram 5-8 slam Rolling BillBoard (Gone not forgot) 2004 Dodge Ram HEMI 10" lifted on 37's and 2wd. |
02-26-2008, 02:29 AM | #3 | |
THANKS, I will take those numbers with me when I go the front end shop and listen to his comments and then tell him that is where I want them set!!!
02-26-2008, 04:07 AM | #4 |
1972 Chevrolet SWB
Those specs are just a general way to get you real close and help keep tire wear to a minimum and are useful if you have a custom set up or cant find specs.
I would like to see what your set up is right now so I could help see what your tire wear issue really is. Like I stated earlier excessive toe in or toe out will create the fastest inside or outside tire edge wear although many think positive or negative camber will do more damage.........not the case,as both will do damage over time but toe in or toe out in excess will cause the fastest edge wear.
02-26-2008, 06:17 AM | #5 |
I will dig out the specs from the last alingment back in late 06 and take some pics of the tires. The ware was not sudden but I have been keeping a eye on the tires for the past year when I noticed the pattern of ware. This is on my 55 1st series GMC with a Mll, and the tires have about 10K on them the tires are 215-65-15 on 7" wheels 3 1/2 BS
02-26-2008, 07:35 AM | #6 |
Who's in CHARGE??????????
This is for a 49...joe
Send a card to a soldier in Iraq My Music PlayList Large Marge Donate Blood,Plasma,Platelets & sign your DONORS CARD & SAVE a LIFE Last edited by TooMany2count; 02-26-2008 at 07:35 AM. |
