Green club
Side pics ECE 4/6 drop and 285/70/15 rear tire
A few members have requested side pics of my truck and the 4/6 drop and 285/70/15's. The fronts are 235/60/15's, gives a nice hot rod rake I get lots of looks in this truck
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears 70 SS396 Chevelle 427/200-4R/3.73posi 61 Lincoln Continental, black on black Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln |
BlahBlahBlah
Re: Side pics ECE 4/6 drop and 285/70/15 rear tire
If your truck was lower in the rear would the tires rub? Oh and what size wheels are you running front and rear? Very nice looking truck.
Really like the look of the rear tires.
Green club
Thanks CG, no rubbing at all. I don't have a c notch on the frame and have had more weight in the bed than I would like to say (axle on the frame) and the tires have plenty of room to roam.
It does have the adjustable bar back there, so side clearence loaded is not an issue.
![]() Join Date: Oct 2005
Love that "fatty" rubber in the back.....just say NO to rubber band tires!
......and that color is way cool.....especially with the color keyed rally's!
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - ![]() My Build Thread |
Tot Roddin'
Beautiful truck!
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
Nice! Tires, wheels, color, stance, ALL of it!...
Are you running 8" rims all around?
laying low
![]() Join Date: Mar 2001
It looks like an 8" wide rim with 4" bs is a good fit for most any wheel/tire combo on these trucks. Front and rear.
That 285/70 looks huge under there but sure fills out the fender opening. ![]()
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
Love The Rake, Static Or Bagged,if Static What Parts Did You Use, Hows The Ride. Thanks Jim
Very nicely done - that color is neutral enough to look good without any chrome. My stock yellow '70 doesn't have any chrome, but I'm thinking that with a louder color, you have to have something to break up all that yellow. Your's looks great.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD ![]() Click here to support the board Philippians 4: 6-7 |
Green club
They are 8 inch wheels all around, 4 inch backspacing, you guys have a good eye
![]() Static drop, no bags. I have the ECE kit, minus the 1.5 springs that they supply. I bought ground force 2 inch front springs I was recommended to buy from summit racing (cheaper than ECE) for a total of 4.5 inches in the front. I pulled a 1 ton sway bar from a wrecking yard and have that up front, I believe this is the large 1.25" one. No rear bar at all, handles quite well for what it is. The ride is good, a little bone jarring over rougher pavement but nothing too bad at all. It tracks well, does not bottom out in the rear with no c notch, unless I have weight back there (over 600lbs or so) I do not regret doing this suspension at all, very well set up. Thank you all for the compliments, it has been alot of work so far ![]()
#13 |
Keep Your Nose Clean
Your truck looks clean. I dig that rake. Is that a chevelle with ralley stripes I see in the garage?
#14 | |
Green club
![]() It's a fun car, I need to get it out more to warm it's rear tires up. I will post pics soon, need to take new ones.
#15 |
Project: years too late.
i love that stance, thats what im going to use for mine!
1971 C10 Stepper LSX 5.3/4L60E 3.73 12bolt posi. Father Son Project. In Memory of Bruce C. Shorten. Rest easy Dad. Ill take it fryom here. |
#16 |
This is how my`67 GMC will be.It has 4/6 drop and 8" wheels.I just have rollers on it until it gets put together.I`ve bought tires too soon before and regretted it.Tires on an occasional driver dry rot before they were out as it is.
#17 |
Green club
Well I took the plunge and purchased some 235/70/15 front tires today to replace the small 235/60's, I will take more pics tomorrow to see what you all think
#18 |
1972 Chevrolet SWB
I think that will look much better,not that it didnt look good already but unless the rear was dropped a tad more I thought the frts were a little on the small side...........I bet it looks way better now with a little taller tire in frt.
My New thread with pics (not my build thread yet.) ![]() http://67-72chevytrucks.com/vboard/s...46#post2573646 1972 Chevrolet 1/2 ton short wide bed,68 frt clip Project. 1980 Camaro Inherited when father passed,68K Miles 2003 Ford Mach1 FUN as Hell!! 2002 Dodge Ram 5-8 slam Rolling BillBoard (Gone not forgot) 2004 Dodge Ram HEMI 10" lifted on 37's and 2wd. |
#19 |
Green club
Thank you, I really thought the front tire was too small. Those tires were off of the Chevelle and got me rolling, but I finally got around to buying a taller tire the truck should look more balanced.
I will take more pics tomorrow, they sure look different ![]()
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears 70 SS396 Chevelle 427/200-4R/3.73posi 61 Lincoln Continental, black on black Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln Last edited by 67shortie; 02-26-2008 at 09:20 AM. Reason: Speeling and beer don't mix |
#20 |
Green club
I put new 235/75/15 front tires on this morning, let me know if this looks more balanced.
#21 |
I think that is a much better look. The stance and everything now looks finished an balanced. Nice truck
1969 GMC 3/4 Ton 4x4 2" Lift, A/C, PS, PB 383 Stroker, 700R4, 205, 4.10 GM Medium Bronze (Copper Poly) no new nick name yet. She is to pretty to be the Beater. http://67-72chevytrucks.com/vboard/s...d.php?t=241855 |
#22 |
i love summertime
looks great
1967 shortbox stepside Chevy, 365 hp 327, th400. GLOVE BOX LIGHTS FORSALE, click link for info http://67-72chevytrucks.com/vboard/s...d.php?t=273724 |
#23 |
Prestige Worldwide
![]() Join Date: Feb 2001
Lookin sweet!
#24 |
Green club
I like it too, I at first when I bought the tires I was a little aprehensive, but after they were installed my fears were put to rest.
It rides much better too, no more harshness over rutted/rough roads that those 60 series tires had.
#25 |
looks much more balanced, i love it beautifle truck!
