02-24-2008, 07:28 AM | #1 |
Dude...I'm a CHICK
Radiator support Q..
Is there a difference between the GMC and a Chevy radiator support?? I was told that there was because of the double headlights, but I cant even find a GMC rad sup. to see a diff.
Thanks junk
~*~*~*~*~*~*~*~*~*~*~*~*~* "The unexamined life is not worth living" -Socrates ~*~*~*~*~*~*~*~*~*~*~*~*~* '71 GMC Suburban 4x4 |
02-24-2008, 08:01 AM | #2 |
Re: Radiator support Q..
If I'm not mistaken, the GMC core support is the same as the Chevrolet 67/68 core support except for the double headlights.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
02-24-2008, 08:05 AM | #3 |
Msgt USAF Ret
The LMC catalog on page 119 shows the same part no.s for both chevy and GMC with the only difference being AC. The headlights are mounted in the grills. Here is a pic. The vendors will be more knowledgeable and I'm sure they will jump in.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
02-24-2008, 08:05 AM | #4 |
Yeah girl,that`s it.The supports are the same other than the light pans.It`s a bit tidious but you can move the light pans from a GMC onto a Chevy core.They don`t repro GMC cores.Is your`s bad?What kinda bad?Just the rust in the bottom?As long as it`s not at the frame mounts I just patch them.They can be patched there,too.Just need to reinforce with thick steel.
02-24-2008, 08:07 AM | #5 |
The headlights are mounted in the core support and the grille just frames them.The grille floats around the lights.
02-24-2008, 08:12 AM | #6 |
Msgt USAF Ret
Thanks I wasn't sure about that.
02-24-2008, 07:28 PM | #7 |
Just go home and make a joke up about it.You`re alright VetteVet,even though you ride those noisey motorcycles.An old man like you should be ashamed.
Hey Jodie,What`s wrong with yours.Wondering if I can help.I may have something better.
02-25-2008, 05:54 AM | #8 |
its all about the +6 inches
actually, if I am squinting enough, the listing doesn't include GMC at all. It has one part number for 67 and 68, then another for 69 - 72, but neither listing says GMC (jodie's burb is a GMC)
02-25-2008, 06:37 AM | #9 |
Hey Jodie, You would have yo buy a 67-68 Chevy rad support and remove your headlight buckets from your GMC support and install them on your new one. They are spot welded on. Tim
02-25-2008, 06:58 AM | #10 |
I've got a rust free original....Let me know.
02-25-2008, 08:20 AM | #11 |
Dude...I'm a CHICK
OK, thanks yall, Ill run this by my body guys and see what they want to do. mine is rusted out and "new" parts are easier to paint. Hopefully just a few weeks from the engine pull, getting excited!!!
