02-24-2008, 07:28 AM | #1 |
Big block Chevy parts
@@@@ MORE PARTS ADDED @@@@
** Parting a 70 GMC Custom Factory Big Block. ** ** If you see anything in the pictures I haven't listed let me know and I will price. ** 4 Core Radiator for auto tranny - $80 Shroud - ** SOLD EIGHTBANGER ** Turbo 400 shift linkage - ** SOLD SS396 ** 400 shift solenoid - ** SOLD JQ-72 ** Power steering pump, reservoir and brackets - $225 Alternator brackets - $75 Auto tranny cross member with e-brake cable brackets - $40 3/4 T Master cylnder with power booster and proportioning valve - $40 Front sway bar - $35 Steering sector -$40 (No Shipping) Dual saddle tanks with all switches and connections - $100 o.b.o. (No shipping) Breather stove pipe tube w/ exh shield - ** Sold Sameyrasme72 ** All prices are plus shipping.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 03-19-2008 at 01:46 AM. |
02-24-2008, 07:31 AM | #2 |
Re: Big block Chevy parts
what year bb stands?? interested if 72`s
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
02-24-2008, 07:35 AM | #3 |
All parts are from a 1970 GMC. More pics....
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
02-24-2008, 08:02 AM | #4 |
do you have all the pieces for the shift linkage
02-24-2008, 08:08 AM | #5 |
I didn't take it apart so refresh my memory on the total number of pieces. They should all be there, but let me check.
02-24-2008, 08:26 AM | #6 |
I don't know for sure how many pieces , the piece that is on the transmission, the piece on the frame, mabe a piece that goes between with a spring , and the rod from the column
02-24-2008, 10:28 AM | #7 |
Hello. Do you know if the brake MC, prop valve and the vac booster are in good working condition? Also would be interested in the T400 linkage if it all is there. I live in NM and couild pick up.
CCCC 67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison Moved but still in the family 70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350 Recently sent to new homes 72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp |
02-24-2008, 10:34 AM | #8 |
Rob, I'm needing the trans kickdown switch and wiring (it's hanging over the brake booster in picture #5)Thanks!
Joshua
72 Cheyenne Super swb. Factory 402/400,tach,posi,AM/FM, A/C. Adding cruise, 8-track 72 Cheyenne Super swb. 350/350 A/C, bucket seats 72 Cheyenne swb. Factory 402/400, tilt, posi, A/C 72 Cheyenne Super K-10. 350/4 spd., posi. 72 Suburban 350/350 tilt, tach, AM/FM, A/C, luggage rack 72 GMC Sierra lwb. 350/350, A/C. medium green/olive interior |
02-24-2008, 10:37 AM | #9 |
Always on the hunt...
Interested the set of towers, the alternator brackets if you will separate and also interested in both crank pulleys and the water pump pulley pending pics & price. Lmk, Cb
02-24-2008, 05:54 PM | #10 |
Could you post a photo of the stove and heat pipe? I want first chance on it.
Dan |
02-24-2008, 06:09 PM | #11 |
Here are the pictures of the stove pipe.
02-24-2008, 06:13 PM | #12 | ||
Let me check the pulleys and make sure they are OK. Are you interested in a package deal for complet p/s setup, pulleys, alt bracket and motor stands?
02-24-2008, 10:44 PM | #13 |
If Dan passes, and you have the base (pics Please), that goes with the pipe, I will take it. .................Jason
72 Cheyenne Super 80 Silverado Blazer 2wd |
02-24-2008, 11:32 PM | #14 |
hey, how much for the radiator and shroud shipped to 85242? it is a 4 core right?
thanks, matt
1970 C20 now a K30 1986 3+3 Dually |
02-25-2008, 12:28 AM | #15 | |
I will guess between $40-50 for shipping, so $200-210.
02-25-2008, 07:37 AM | #16 |
I found 4 pieces which I think is all there is. Let me know.
R/
02-25-2008, 07:42 AM | #17 |
454 MAKES IT ROAR
PM Sent re Shroud
Put me down for the shroud if Matt passes.
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger Last edited by eightbanger; 02-25-2008 at 08:09 AM. |
02-25-2008, 08:30 AM | #18 | ||
8banger, you're second. I've never shipped to the UK before.........
02-25-2008, 06:59 PM | #19 |
02-25-2008, 07:21 PM | #20 | |
Thanks, PM sent with details. R/
02-26-2008, 04:26 PM | #21 |
Ttt
02-26-2008, 05:31 PM | #22 |
Thank You , PM sent
02-26-2008, 10:20 PM | #23 | |
SS396: No thank, you . I'll get it shipped out this week.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 02-26-2008 at 10:20 PM. |
02-26-2008, 10:45 PM | #24 |
Still have the radiator? Also how much shipped to 28787?
02-26-2008, 11:10 PM | #25 |
Passing interest on all of the above due to no pulleys being available in the package. Thanks, Cb
