solenoid or starter switch?
I got this 6cyl 250 I got running after a 14yr old dirt nap. let it run for 30min and turned off and it wouldnt start, turn over. I cross the solenoid and fires right up, turns off with key but still wont turn over. It was fine earlier today.
Even the nicest dodge-chrysler is only 2years away from being parked outside of Section 8 housing. |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Re: solenoid or starter switch?
Jiggle the shift lever in park or neutral while turning the key switch to start. It is an automatic right.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
no 3 speed column. sorry
ttt
knuckle buster..
![]() Join Date: Oct 2007
check the ignition switch with a voltage tester or test light, if not then check wiring to starter.
_______________________________________________________________________________ Eric THIS SITE ROCKS!!! ![]() Check out my suburban on 20's with fresh paint! Click here to support the site Check out the Member Photo Gallery here StreetCruizin FAQ thread Site vendors list (scroll down to vendors in red) ![]() ![]() |
"Ochre Ogre"
Did the heavy red wire at the poss cable pop the inline fuse or become disconnected? How about the connection at the junction block on the fender? That is the hot wire that feeds into the cab. Trace that wire with a test light. If you have 12v up to the switch but not after then the switch has gone bad.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
now today I hit the key and it turns over. I dont know if the starter or solenoid was hot or sticking. Class, anyone? Bueller? Bueller?
Im cheating here. Its a 68 but a 68 chevy biscayne.
to da burb
Did the heavy red wire at the poss cable pop the inline fuse or become disconnected? How about the connection at the junction block on the fender? That is the hot wire that feeds into the cab. Trace that wire with a test light. If you have 12v up to the switch but not after then the switch has gone bad. I will check this but if the switch was bad then it would be bad and not be fine later, as in the case today when it woud turn over fine from the key. I know this car will have some eletric gremlins from sitting so long.
"Ochre Ogre"
Sounds more like the switch if you didn't mess with any wires or cables under the dash. Or it could just be corrosion at any of the different contact points.
my 67 did this after siting forever. It would fire, run great then sometimes, nothing. Turns out the battery cable would hit the exhaust and ground out. killed the starter, but Got lucky and never burned it down or melt the wires, but that was the problem.
1969 4x4 Nothing beats a good rock drill and some dynamite |
Old member
I had to replace the key switch. The plastic on the back side had melted and when it got hot wouldn't let the wires make contact. I looked for day's trying to figure it out.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
