Old 02-24-2008, 10:30 AM   #1
nyncompute
nyncompute's Avatar
Stock vacuum guage hook up info
I'm about ready to install my guages and I've never seen much info on the way you hook up a line to the back of a stock vacuum guage. Any picks? where to get the hardware and do you take it off the manifold?
1972 K-10 SWB Cheyenne
nyncompute is offline   Reply With Quote
Old 02-24-2008, 10:38 AM   #2
Husker
Husker's Avatar
Re: Stock vacuum guage hook up info
I just did the Dash I got from a board member that has a Vacuum guage in it I got some 3/16" flexible copper line and fittings at Ace Hardware (3/16's fit the ferrule on the guage). I went right to the Manifold behind the carb. Went through the firewall where the oil line goes through.Worked pretty good. I did curl the end of the line up a bit for flex in the Motor Mounts.
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 02-24-2008, 10:11 PM   #3
nyncompute
nyncompute's Avatar
I wonder how they were routed on the original hevier trucks? Sounds like a plan though.
