02-24-2008, 12:06 PM | #1 |
single wall vs double wall top
looking to buy 70-72 2wd blazer or jimmy, wondering what is the difference between the single wall top and double wall? were both offered from the factory? anyone have pics of the differences?
02-24-2008, 01:53 PM | #2 |
Re: single wall vs double wall top
single wall bolt thru the top into the bed. Double walls bolt thru the bed into the top. And singles have a dome light. I think doubles look a little cleaner, but much harder to take off. The bolts are under the side panels. Started singles in 72, but used up all their doubles first. So many 72's had single.
02-24-2008, 08:25 PM | #3 |
I think single wall tops are stronger, and less likely to bow(on top). Double wall tops seem to be worth half what a single wall top is worth, not sure if they are just better or just not as many exist.
02-24-2008, 08:51 PM | #4 | |
SKINNY TIRES RULE!
double wall tops show more sag and can have a tendency to split at the seam. Dobule walls are also heavier, but I don't know if there is really enough weight difference to really notice since they are both heavy and awkward to handle.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
02-24-2008, 10:10 PM | #5 |
I Agree With Bouncy
Both Heavy And Awkward I Think Interior Trim Should Dictate Wich You Should Want Rear Side Panels=single Wall (bolt In From Top No Removal Of Interior Panels) No Rear Panels=double Is Ok (bolt In From Bottom Of Bedside) Trust Me Both Can And Will Crack If Not Taken Care Of Or Not Installed Properly Ie:not All Of The Mounts Bolted In And Then Offroading Po. Proved That To Me |
02-25-2008, 12:37 AM | #6 |
Keepin it runnin!
I'd go with a single wall. I have a double wall and the steel inserts in the top are old & a few are stripped. Also when the seize up and youtry to remove the bolts, the inserts rip the fiberglass. Go Single wall IMHO.
Frank
1970 K-5 4X4 Blazer 1970 K-20 4X4 Long Bed "Liberty Means Responsibility, that is why most men dread it" |
02-25-2008, 12:46 AM | #7 |
old man jimmy and bouncytruck are saying the same thing.
That is why I bought a single when I had a Jimmy. The single you could take on and off without messing with the side panels.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
02-25-2008, 02:24 AM | #8 |
The LuvShack Garage
Ya gotta look kinda closely, but here are some pic's along the rear
windows. BTW if ya buy a 72 it might be set-up for either, "GQ" is. In these pictures, the Black is a Double, the White is the single (Look around where the top meets the glass, it's more noticable)
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T Last edited by LUV2XCLR8; 02-25-2008 at 02:25 AM. |
02-25-2008, 04:49 AM | #9 |
SKINNY TIRES RULE!
Keep in mind, 2wds are pretty rare so you may end up waiting a long time for one with a single wall.
02-25-2008, 07:24 AM | #10 |
thanks for the info guys.
02-26-2008, 08:23 PM | #11 |
Also the tops have different bolt hole locations in the bed.
70 Jimmy 4x4 71 GMC 2500 Too bad stupidity isn't painful |
02-27-2008, 06:00 AM | #12 |
The only really nice top on a blazer is the invisable one as topless is the way to go. forget A/C or softops---just use it as it was desinged TOPLESS RULES---I gently take her top off in april and don't cover her up till November. She seems to like the sun, the air blowing through her inners and gets more looks then any blazer with it's top covering it's assets!! Try topless, you'll love it!
02-27-2008, 06:16 AM | #13 |
I Had No Idea They Were Different Bolt Holes
Thats Kinda Silly |
02-27-2008, 06:53 AM | #14 |
The LuvShack Garage
Yes it is, but some were set-up to take either, my 72 is "GQ"
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
02-27-2008, 08:08 PM | #15 | |
02-27-2008, 08:28 PM | #16 |
Future TOTM Winner
So is the Critter.
I'm not a big fan of the soft tops. Never had one on a K5 but had some bad experiences on some CJs in the past. I'm a topless fan unless weather is bad, then the hardtop goes on.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
02-28-2008, 04:57 PM | #17 |
...but you can`t take it with you.
