Old 02-24-2008, 09:10 PM   #1
hdrider
1982 fuel pump mix up ?? need help
got a 1982 GMC 5.0...went to parts store to get a new fuel pump...the one on their systom dosent mach the one that i took off...it {the one on their systom}has a much shorter cannister...i was told the one i had was off of a 400 block...had truck for 12yrs...could it be the previous owner put this pump on???...or is there another reason it was on my truck from factory...i installed the pump matching up to the one that came off & it broke in 30sec. need some feedback on this......tks
hdrider is offline   Reply With Quote
Old 02-24-2008, 10:34 PM   #2
beaterC10
Re: 1982 fuel pump mix up ?? need help
The only difference I am aware of is the SBC pumps have an inlet and outlet, the later pumps have inlet, outlet, and vent. If the outlets are correct and the pushrod is correct I wouldn't think the height of the pump body would matter.
beaterC10 is offline   Reply With Quote
Old 02-25-2008, 10:52 AM   #3
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
All SB used the same fuel pumps. Differences were ports.
How did the pump fail? Was the push rod installed properly? How many ports on the fuel pump you removed?
gchemist is offline   Reply With Quote
Old 02-25-2008, 06:10 PM   #4
hdrider
i am assuming the diafram went bad...on further inspection i noticed the arm comming out of the new fuel pump that broke in 30sec. is slightly longer than the orig pump...i also found a number stamped on orig pump that parts store crossed reff. and it came up on their systom & will be picking up today...pump has 3 ports...but still cant figure out why the pump that came off truck is different than the one that parts stores systoms show...being that the cannister is over twice as long...will find out today what the new part goes on...one guy told me its for a 400 block
Old 02-25-2008, 08:55 PM   #5
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
bring the one that was original there with you and dont settle for anything other than a complete identical match
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 02-25-2008, 09:36 PM   #6
hdrider
the orig unit has 3 ports...in..out...& the 3rd im assuming a vent line...could there be a diff. in rate of flow ???
Old 02-25-2008, 11:53 PM   #7
James McClure
One shot, one kill.
HD. The 3rd line is a return line. Inside the pump is a pressure regulator. Anything over 13 or 14 psi gets returned to the tank. This has an effect on emmissions also by keeping the fuel cooler and limiting evaporitive emmissions. jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose.
James McClure is offline   Reply With Quote
