Hey Watch this...
![]() Join Date: Sep 2007
Birthday Present Time
So, luckily I sold my other house, so I didn't have to sell the tomato. My birthday's coming up and the wife is 'getting' me a new exhaust for the truck. That, and I'm going to get the new suspension (2/4 drop, Belltech gear) at the same time. So.. two questions:
1) I found a shop that will do a manifold back, but I can't decide on the package. I'm going to have the exhaust exit in front of the rear tires, under the step. I don't want a 'straight pipe' loud, but I want it to make that diminutive 283V8 sound mean. Any suggestions on mufflers? 2) The truck currently has 235/75-16 Goodyear Wranglers. The main question is if I'll rub due to the drop or not. I'm not concerned about the fender inner or outers, but the height of the tires causing contact. If there's a chance of that, I'm thinking of going with something like 255/60-16s. Anyway, does anyone think the current tires will rub after a drop? cheers!
What have I gotten myself into now? 1964 Chevy Stepside - 383 hydraulic roller Vortec ... a work in progress 2000 Volvo V70R - 340awhp, 22psi, meth-injected of Porsche-eating fun. The grocery-getter on steroids |
Resistance is Futile
Re: Birthday Present Time
I dont know the hite(diameter) of your tires.........my truck has a 26.5" front tire and is lowered 5.5" and has a couple inches to go. 2" front drop is very mild.
My burb is lowered 3.5" in front w/ a 29" tire.......no problems. If you are after a "classic" hot rod sound.......glasspacks all the way. I just heard my neighbor drive by in his 69 Impala w/ 307 and glasspacks. Kinda fuzzy sound.........
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
Registered.........
If you want a thumpin' " big " sound, use some 40 series flowmasters (two chamber type). A fella in my car club has them on one of his chevelles (1964 300 series wagon, TWO door with a 283) and he could fool anyone into thinking that it was a 350.
1966 C10 panel-400 small block/TH 350 combo Nothing is fool proof to a talented fool! Popcorn: Pops at exactly 444 degreese Expands to 44 times it's original size Has a 4 year shelf life |
Hey Watch this...
Flowmasters. Check. Thanks man.
I did some measuring today and it looks like there's plenty of room for the (too tall) tires... for now. I'll 'have' to replace them when I find a good deal. They're 245/75-16s, with tons of room for wider rubber. ![]() I also did some thinking and I'm going to go to 3" springs front, and go 5" in the rear, also after a bunch of measuring. The main question is if I need to get an adjustable track bar. It looks like, by my research, that at a 5" drop, I'd be on the cusp of needing it. Is there any risk in not doing it, and then deciding afterwards that I do need a non-stock bar? Thanks for the advice guys.
What have I gotten myself into now? 1964 Chevy Stepside - 383 hydraulic roller Vortec ... a work in progress 2000 Volvo V70R - 340awhp, 22psi, meth-injected of Porsche-eating fun. The grocery-getter on steroids Last edited by javadoc; 02-26-2008 at 06:45 AM. Reason: . |
#5 | |
Hey Y'all!!
My truck has a 3"/4" drop on it with the stock panhard. I have 235/75/15's all the way around and have not had any problems at all. Ultimately, I plan to go with a wider tire and drop the rear one more inch. At that point I will also be putting on an adjustable panhard (so I can re-center the rearend to provide more tire clearance), but, until then, everything is working great. Good luck! |
Personally I'd hate to have the tire hit the fender on a big bump so I'd just go and do the panhard bar while your doing the suspension. You'll be under there so why not...
Hey Watch this...
[QUOTE=leftcoast66;2596085]Personally I'd hate to have the tire hit the fender on a big bump so I'd just go and do the panhard bar while your doing the suspension. You'll be under there so why not...[/QUOTE
Yeah, and it's only about another $100, right?
Hey Y'all!!
I still stand by my previous post based on your statement "tons of room for wider rubber" and the fact that I have hauled loads of gravel, rock, sand, you-name-it and still had no issues with the tires rubbing anywhere with the size tire I am running right now. All the adjustable panhard is for is to recenter your rearend for maximum tire clearance and to keep the track in line with the front. I was on a REAL tight budget when mine was initially lowered so the extra $100 was the deciding factor for me. If you've got the extra $$ then go ahead as you will ultimately need one when you go with a fairly wide tire. Otherwise, it ain't gonna hurt nothin' for time being. Just my $.02 worth. Good luck whichever you decide!
You can cut the ends off of your factory panhard and weld a new piece of rod between them.... Then you would also need new bushings too after that heat.
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=269019 Petitioning *No Regrets* MD/WV |
Registered.........
Regarding the panhard rod you have a couple of options, I have seen an adjustable one for as little as $65.00 new OR if you or any one you know has access to a chopsaw, lathe, 24" to 30" length of 5/8" I.D. 1/8" wall DOM tube (cheap, scrap piece cost me $2.50 at my local metal shop - found it in the scrap bin), two 5/8" nuts to match the thread pitch of your tap and die (I used fine thread stuff) and a 5/8" tap and die you can do what I recently did to make my factory one adjustable.
After measuring the overall length of the panhard rod to use as a reference, cut the panhard rod in two at the middle of the bar, then chuck each half (one piece at a time of course) into the lathe and turn the outside diameter down from 11/16" to 5/8". You then cut of the excess leaving about 6" of rod from the end of the eyelet and use your die with oil to cut 5/8" threads into the original rod ends. Then use your tap to tap threads into the 5/8" I.D. tube running the tap in as far as you can. Once completed, install the nuts onto the factory rod ends then thread the rod ends into the tube. I spent about 1 1/2 hours on mine and a total of $14.00 for the tube, nuts, and a cheap tap and die from my local Harbor Freight.
1966 C10 panel-400 small block/TH 350 combo Nothing is fool proof to a talented fool! Popcorn: Pops at exactly 444 degreese Expands to 44 times it's original size Has a 4 year shelf life Last edited by wild one; 02-26-2008 at 12:37 PM. |
