02-25-2008, 05:32 AM | #1 |
door panel idea
My 36 year old door panels were showing their age so I decided to refinnish them. Have not seen anyone do this so I thought I would put it up. Of course my truck is just a weekend playtoy so I dont care if it looks perfect or not, just as long as it looks better than before!
heres the pics, cost me a total of 16 bucks....$4 for epoxy, $6 for the black vynal dye $3 for the leather crap 1/2 off from fabric store and $3 for the foam 1/2 off at store. |
02-25-2008, 05:34 AM | #2 |
its all about the +6 inches
Re: door panel idea
much better.
Now... if only your socks matched! |
02-25-2008, 05:38 AM | #3 |
I have a radical idea!
Re: door panel idea
Definitely a 100% improvement! I know this is going to sound crazy, but you can take some very fine steel wool and lighty "wet sand" the vinyl dye on the grain areas of the of the panel, it will dull it out just enough to look almost exactly like the factory plastic finish on the door panels. It just takes that shiny sheen off of it. Either way, look much better!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
02-25-2008, 05:39 AM | #4 |
Re: door panel idea
nice! info on the dye?
02-25-2008, 05:44 AM | #5 |
Re: door panel idea
LMAO
Panels look good!
1972 3/4T 4x4 Chevrolet (383) 1971 c-10 SWB (400 sb) 1972 4x4 Blazer 1969 SWB 4x4 GMC Projects: 1972 stepside 4x4 http://67-72chevytrucks.com/vboard/s...d.php?t=280132 http://67-72chevytrucks.com/vboard/s...d.php?t=285952 http://67-72chevytrucks.com/vboard/s...d.php?t=553672 http://67-72chevytrucks.com/vboard/s...d.php?t=522704 |
02-25-2008, 05:48 AM | #6 |
Re: door panel idea
wow thats awesome for that price
and i gotta ask to, whats with the socks?
Travis
travis_moffatt@hotmail.com 1969 Chevrolet C-10 LWB, 350c.i., TH350, In Pieces. 1991 GMC Sonoma, IROCS s10 grill 1963 Ford Galaxie 351/C4 |
02-25-2008, 05:58 AM | #7 |
Re: door panel idea
about the socks: its saturday!! im too lazy to try and match socks.
for the dye, I just used the autozone stuff, used it before and it works really well. 67-C 30, Ill try to get some steel woll, I think it would look better loss glossy. |
02-25-2008, 06:11 AM | #8 |
Re: door panel idea
What about a clear coat spray. I would think that would help on the wear and tear. Do they make a clear coat spray that isn't glossy?
john
02-25-2008, 07:16 AM | #9 |
Re: door panel idea
look great
02-25-2008, 07:37 AM | #10 |
Re: door panel idea
here is my refresh job. no clear on it as it tended to fog it.
02-25-2008, 09:41 AM | #11 |
Re: door panel idea
You're right, it is intended to be fogged.
The satin clearcoat may be a good idea, but PLEASE make sure you paint something else with the dye, let it dry, and then try it first. A lot of the newer higher quality vinyl dyes and spray paints have a lot of enamel in the mixture, and they will react like wrinkle finish paint when recoated after they have dried. Duplicolor paints are especially bad about this. It will look a lot worse with the dye all cracked up and blistered so I'd try it on a test piece to make sure it the satin clear doesn't react with the dye. If you do go with the clear, it will work best if you hold the can 12-14 inches away and fog the panels with several lights coats.
02-25-2008, 10:02 AM | #12 |
Restoring a 68 SWB
Re: door panel idea
02-25-2008, 12:37 PM | #13 |
1972 Chevrolet SWB
Re: door panel idea
Nice work,always better to upgrade what you have already especially for cheap.
I have 2 offwhite deluxe 72 door panels I cleaned up and painted grey and I also have one stock black deluxe door panel from passenger door........are these desireable or should I just hang onto them??
My New thread with pics (not my build thread yet.) http://67-72chevytrucks.com/vboard/s...46#post2573646 1972 Chevrolet 1/2 ton short wide bed,68 frt clip Project. 1980 Camaro Inherited when father passed,68K Miles 2003 Ford Mach1 FUN as Hell!! 2002 Dodge Ram 5-8 slam Rolling BillBoard (Gone not forgot) 2004 Dodge Ram HEMI 10" lifted on 37's and 2wd. |
02-25-2008, 01:36 PM | #14 |
Re: door panel idea
Much better!
02-25-2008, 02:33 PM | #15 |
Neighborhood Pickle Slinger
Re: door panel idea
Thanks for the ideas with the door panels.
Oh, for all of you disturbed by unmatching socks, I fixed them.
-------------------------------------------------- My C10 Diary Our cars: 1966 Chevrolet Chevelle 396 - TH350 1968 Chevrolet C10/CST 327 TH400/375 1969 Corvette Stingray 350 - Muncie Manual Trans 1969 Chevrolet ElCamino 350 - TH400 1970 Cutlass Supreme Convertible - 350 Rocket - TH350 1973 Camaro LT - New Engine Done - TH350 1973 Corvette Convertible 454 - TH400 |
