Old 02-25-2008, 05:47 AM   #1
JAB'70
Any one ever tried Seafoam??
I was wondering if that seafoam stuff really works. I have 350 in my '70 c10, I've did quite a bit of work to the motor since I last year. The previous owner did keep the maintenence up on it and I plan on getting a rebuild once my funds are saved up. I was told that seafoam would do wonders for it until I get around to rebuilding the motor.
JAB'70 is offline   Reply With Quote
Old 02-25-2008, 06:22 AM   #2
harmsy
Re: Any one ever tried Seafoam??
I'm not a fan of seafoam....Maybe its because I sell Justice Brothers.
God bless the USA
1972 Chevrolet Cheyene Super ......
harmsy is offline   Reply With Quote
Old 02-25-2008, 06:42 AM   #3
Sweet72
Sweet72's Avatar
I'm not a fan of the "overhaul in a can" products, but have used Seafoam in an 200k mi. 302 blue oval motor when it had a sticking exhaust valve/lifter. Directly in the engine oil and idled for 10 min and then changed oil. I got lucky, the valve freed itself after a few miles. Also pulled a can through the intake via the brake booster vacuum line and man did it smoke! follow the directions on the can and good luck.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 02-25-2008, 07:10 AM   #4
cdowns
cdowns's Avatar
when i see foam i drink it
Old 02-25-2008, 07:34 AM   #5
tkeduk8r
tkeduk8r's Avatar
I like it... is it a miracle cure... no, but just like ny other tool when used correctly I thnk you can get positive results... I like to use it on older eninges to remove carbon from valves, seats, ports and piston tops by sucking it through a vacuum line into the intake... one can per motor and it seems to have worked... I have had my auto students pull a head, look at the build up, re-install it, run a de-carbonizer (seaform, JB or other) and remove the head a second time and it does do a bit of cleaning... super clean.. no, but significantly better than before.. yes... GM and 3M sell intake cleaning kits that use basically the same chemistry albeit you can run it into your fuel line via a schraeder valve... JMO...
--Mike
63 C20 2WD, 230/SM420/4.11 73K
68 C30 dump truck, 327,SM425,4.56 66K original
68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes
68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79
69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi...
70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP
72 Chevy K20 4x4 350/350/205/4.56 donor
72 Vette 350/M21/3.70 posi, triple black and super fast
84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's
tkeduk8r is offline   Reply With Quote
Old 02-25-2008, 07:37 AM   #6
Sweet72
Sweet72's Avatar
LOL!
Old 02-25-2008, 07:37 AM   #7
GREASEMONKEY72
GREASEMONKEY72's Avatar
do a search on the forum and youll find a few threads about it with alot of info on it
i have used it personally and it does make a big improvement in performance
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 02-25-2008, 07:41 AM   #8
79oldj
I personally like it. Never was a big fan of cures in a can, but I have used it with some success on million mile bowties,and lawn mowers and other used and abused engines.
79oldj is offline   Reply With Quote
Old 02-25-2008, 07:43 AM   #9
463
463's Avatar
the seafoam works! i use it in all my engines. 463
463 is offline   Reply With Quote
Old 02-25-2008, 07:53 AM   #10
1BAD64
1BAD64's Avatar
how about on a 88. just suck it through the brake booster line?
1BAD64 is offline   Reply With Quote
Old 02-25-2008, 07:55 AM   #11
GREASEMONKEY72
yes
-steven
Alte Seele S.S.
Old 02-25-2008, 07:56 AM   #12
1BAD64
1BAD64's Avatar
was wondering cause ive got a valve chattering when i get on it.
Old 02-25-2008, 08:03 AM   #13
GREASEMONKEY72
put half the can in the crankcase and drive around a bit and once you get back then suck the other half through the brake booster then shut it off once its all in and wait about 10min then start it and let it idle till the smoke clears then change the oil
-steven
Alte Seele S.S.
Old 02-25-2008, 08:04 AM   #14
1BAD64
1BAD64's Avatar
thank you for the info. so if my motor blows you will fix it? just kidding lol
Old 02-25-2008, 08:17 AM   #15
70' GMC
HERE.......Somewhere
70' GMC's Avatar
I poured a little bit through the carb, and it did wonders it blew smoke out the back of the tail pipes. I then poured the rest in the gas tank, then went and got some 93 octane which helps it run cleaner.
Current rides: 2013 Hyundai elantra gt DD
1995 camaro my first crush lmao
Was: 1970 with a 350 4barrel and 288 horses
Classics make it possible!
70' GMC is offline   Reply With Quote
Old 02-25-2008, 09:02 AM   #16
crazy longhorn
Fabricate till you "puke"
Everybody has there own favorite I guess.....I like to run a couple bottles of Techron consentrate through my 69 after it sits for the season. Chevron puts this out, as a fuel injector cleaner, but its also good to clean up the valves. Just dump it in the tank & drive. IMO, the best injector cleaner I have used....I use it in the wifeys 03 B ville, & my 93 turd ranger also. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-25-2008, 09:12 AM   #17
mvfd70
mvfd70's Avatar
I use seafoam and I like it. I pour a can of it in the gas tank every 5000miles or so in my z71 and my wife's jeep. Helps keep valves clean and I see a little increase in performance
1978 Chevrolet Silverado 3/4 ton 400 small block.
2000 F-250 Powerstroke
2002 GMC Yukon Denali XL
mvfd70 is offline   Reply With Quote
Old 02-25-2008, 09:37 AM   #18
ERASER5
ERASER5's Avatar
I like Sea Foam. I use Sea Foam. It is not a "tune-in-a-can."
It is a cleaner. A powerful cleaner. Use as directed. Do not under any circumstances leave Sea Foam in the carb or in the oil pan. The Sea Foam, after attacking the gunk, will then eat certain metals fast. Diluted in the gas is fine.
This is a case of a little goes a long way.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 02-26-2008, 04:08 AM   #19
JAB'70
Thanks, I appreciate the info...may or may not give it a try.
Old 02-27-2008, 10:49 AM   #20
straitnate14
straitnate14's Avatar
worked wounders in my freinds 87 5 liter beater that it had a terible idle and low throttle issue and it fixed it it was like a brand new engine, got to love the smoke screen affect
straitnate14 is offline   Reply With Quote
Old 02-27-2008, 11:21 AM   #21
tim21391
tim21391's Avatar
i heard that if you pour too much that it will run sh**ier that true?
tim21391 is offline   Reply With Quote
