Fuel tank switch '86 vs. '87
I recently bought a fuel tank switch to use on my '86 truck. It turns out the switch I bought is for '87 and newer.
On the switch one of the four "poles" has a "bump". The only difference I can see is that the "bump" is on a different "pole" on the two switches. My question is, if I can remove the bump on the newer switch will it work on the older truck? I have to assume there is something different about the switches or why would they make them different? But if one will work in place of the other I will just figure out a way to remove the bump.
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
Re: Fuel tank switch '86 vs. '87
Oops, meant to attach this picture.
I think probably the same, bumps notwithstanding. To keep it simple, I would ohm meter each terminal and match them to one another. You're checking for s/w terminal continuity, not ohm resistance. I just changed my 87 s/w out and the orig one looks like yours on the left.
Gene ![]() Last edited by blu87; 02-25-2008 at 09:07 PM. |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
I would check them, they require different PN', but I don't know if it makes a difference. The 87 does have electric pumps...
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
