go cyclones
4X4 700r4 question
Ok guys, and gals. I did a search on swapping out the 350 for a 700 but didn't find much information on how to do it with a 4X4. I saw that the 700 is 1-3/4" longer. The question is do I move the engine forward or the transfer case backwards? Or a combination of the two. I would like to move the engine forward because the way it sits now the HEI rubs slightly on the firewall. Thanks any help will be appreciated the frame is going to the body shop tomorrow.
Re: 4X4 700r4 question
If you have room I would move it forward. You will also save money by not having to make a new front driveshaft and shorten the rear one.
I did the 350 to a 700r4 swap in my '72 'burb.
I posted some of my experiences back in 2005. I think it should answer many of your questions. Here's the link: My 700r4 experiences
my 2¢ - t.i.o.l.i. Bowen 1968 K20 fleet 1969 K10 swb fleet 1972 K10 Suburban 1972 C10 lwb step 1992 K1500 'burb 1995 K2500 'burb 1997 C1500 'burb 1999 K1500 2000 K1500 'burb Why do I own so many Suburbans? |
Move the motor forward...
I guess one thing that thread didn't really address is the motor mounts. I moved the crossmemeber that the mounts are on forward. I had to drill new holes to mount the crossmember in. Not a big deal, but it's 8 new holes in the frame. Measure at least twice, so you only have to drill once. I have 10 new holes in my frame!
Oh, and I did have to trim my fan shroud a touch for the power steering pump and for the harmonic balancer. Not much, just a couple little notches, and it was easy to do. If you have any more questions or specific questions, ask. I might not see this thread again (I don't come by as much as I used to), so if you ask me something and I don't reply, PM me and I'll come back and find the thread.
![]() Join Date: Dec 2004
After Reading That,do I Need A Different Adapter Or Will My Th350 To Np208 Transfer Case Adapter Work
21 2500hd duramax 58 apache HILLJOB GRAPHIX--for all your graphic needs My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=542497 LS ENGINE SWAP INFORMATION THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=377348 4l60 to an NP205 http://67-72chevytrucks.com/vboard/s...43#post3697343 |
remember to watch oil pan to front diff clearance if the truck does not have a lift, it might be fine, but remember to check for suspension movement.
Not sure about the np208, but whoever you get your tranny from should know. If they don't, I'd be a little nervous about getting one from them.
I didn't have any problems with oil pan clearance, and I'm stock height. I thought I'd have front driveshaft vs. tranny pan issues, but there actually was plenty of room.
![]() Join Date: May 2007
I read on a different board that a th350/np208 and a 700r4/np208 adapters are different. Do you already have what you need or just researching.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
go cyclones
no i am in the process of getting one, I will probaly give bowtie a call tomorrow
