Old 02-26-2008, 03:48 AM   #1
vinneys69
Question split rims and tube tires
Hi i'm new bought a 69 c30 with weekender camper it has inner tubes on all 6 the front have split rims back are dualley are they any good ? should i replace just split rims or replace all with non inner tube type? i plan on going to pueblo co from rancho cucamonga ca in may also once in co i will change to flat bed for hauling will the dualley rears be better or one larger on each side any info will be helpful Thanks VINNEY
vinneys69 is offline   Reply With Quote
Old 02-26-2008, 04:01 AM   #2
slammed1
1972 Chevrolet SWB
slammed1's Avatar
Re: split rims and tube tires
finding a shop to actually work on split rims anymore is the real trouble,so getting rid of those would be the most important part I see right now.
My New thread with pics (not my build thread yet.)
http://67-72chevytrucks.com/vboard/s...46#post2573646
1972 Chevrolet 1/2 ton short wide bed,68 frt clip Project.
1980 Camaro Inherited when father passed,68K Miles
2003 Ford Mach1 FUN as Hell!!
2002 Dodge Ram 5-8 slam Rolling BillBoard (Gone not forgot)
2004 Dodge Ram HEMI 10" lifted on 37's and 2wd.
slammed1 is offline   Reply With Quote
Old 02-26-2008, 04:19 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I would replace them, and destroy the old ones. We had a guy get killed from one popping in the motor pool next to ours when I was in the army.. .this was only 10 years ago or so. Everything was done right, it was aird up in a cage like required, installed on the truck, then as soon as the truck was lowered to the ground, BOOM.
Old 02-26-2008, 04:22 AM   #4
hilljob26
hilljob26's Avatar
split rims are wicked.i have changed them for people for 15 years,yes ,ever since i was 14.anywho,i got too see a splitwheel blow apart as my boss was airing it up about 10-11 years ago,it took his arm off at the shoulder and ripped about a 10 inch long gash down his leg.just spend the cash and get new ones,i would get rid of all the tubes just for the fact that they will never balance out and you will have bad vibrations
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline   Reply With Quote
Old 02-26-2008, 06:39 AM   #5
caminokid
Chevy nut
caminokid's Avatar
That was the first thing I did with my last 71 3/4 with splits. I took them off and destroyed them. I have seen them blow apart...and heard way too many bad stories.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II
"Remember kids there is NO replacement for displacement!"
caminokid is offline   Reply With Quote
Old 02-26-2008, 06:43 AM   #6
vinneys69
Thumbs up Re: split rims and tube tires
Thanks For The Info I Will Get Rid Of Those First Do You Think Dual Rear Tires Are Better Or Just One On Each Side?
Old 02-26-2008, 07:30 AM   #7
caminokid
Chevy nut
caminokid's Avatar
I like duals.
