brakes ?
ok went this morning and got a new master cylinder for a 73 1/2ton c-10 cuz my 65 has newer 5 lug disk swap and i got rear disk to. so i go to the local u-pull-it to look for a booster to get for the cheap as a core, well i come across two 70 or 80's model chevy trucks with hydro boosters on it would i be better off get one of them since my 65 has 24's on it and im building a 383 with about 460hp and for a portioning valve i was going to get one from cpp for $75 for disk/disk not disk/drum. will the hydro boosters help me stop better with the biger wheels. thanks for any help
ridin big yo 5in cpp lowerin springs in back lowered 3in in front with cut springs for now 5 lug swap and disk in front 5 lug and disk in the rear with 3.23 gears mild 350/400heads 7547weiand intake 600 Edelbrock chrome block hugger headers 2 1/2 pipes in to a x pipes super 40 flows and turn downs turbo 350 with shift kit |
Re: brakes ?
oh and if i get it what should i get off the truck it look like every thing was there.
Re: brakes ?
does anyone kno if i need to move this somewhere else
Re: brakes ?
I'm not too sure about this, but the booster pulls equally on both circuits, not one more then the other. What I'm saying is the hydra boost setup provides the pull on the master cylinder equally, so if you have the right master cylinder, a hydra boost should be the ticket. Hydra boost uses the power steering pump to provide power for what the vacuum booster usually does, so yo should be on the right track.
PS your truck would look sic laying rocker on those 24's! |
Re: brakes ?
Do you have an idea what your idle vaccum on the engine is? If you have enough cam to make 460 HP, you may find the vacuum a bit low. If so, the hydroboost booster would work better than a vacuum booster since the hydraulic pressure isn't affected by vacuum or engine load.
Of course, this assumes you have a power steering pump on your 383.
Greg 64 GMC Suburban - 283, NV3500, 14 bolt 77 C10 swb - 292, SM465, 12 bolt |
Re: brakes ?
it going to power steering pump on the 383 and no i dont no what the vacuum is
ridin big yo 5in cpp lowerin springs in back lowered 3in in front with cut springs for now 5 lug swap and disk in front 5 lug and disk in the rear with 3.23 gears mild 350/400heads 7547weiand intake 600 Edelbrock chrome block hugger headers 2 1/2 pipes in to a x pipes super 40 flows and turn downs turbo 350 with shift kit Last edited by 65 on 24's; 02-26-2008 at 07:25 PM. |
KOFFIN DRAGGER
Re: brakes ?
keep in mind that BIG wheels require BIG brakes, the bigger wheel increases rolling mass even though overall diameter is close to the same as stock. you dont need to use aftermarket stuff, just look for newer chevy stuff at the wrecking yard, my new chev has 17 inch rotors on both ends. make take alittle modifying to fit and work, buts only metal. good luck
#8 | |
Re: brakes ?
KOFFIN DRAGGER
Re: brakes ?
your off to a good start, four wheel disc will help alot. the hydroboost will help alot as well. I just dont want your next post to involve an accident because of no enough brakes for your wheels. good luck
Re: brakes ?
it want cuz i had the truck for 3 years and i had the wheels for a year and they probly had 10miles on the wheels cuz i keep have brake prob and it not cuz the wheels im prob with the brakes they where screw up be for that
Re: brakes ?
#12 | |
Re: brakes ?
Atleast that's all I get out if it Prerunner Last edited by leftcoast66; 02-28-2008 at 08:30 AM. |
#13 |
Re: brakes ?
sorry about that but yea that what i mean thanks leftcost66
