I am new to the site. Doing a groud up restore on a 62 C10 automatic 2 wheel drive long bed.
Question 1) Can I use the front crossmember from an 85 chevy c1500 and bolt it on to the 62 so i can have the power steering and disk brakes? Any problems i might find or any suggestions Question 2) How hard is it to put a 350 in to replace the 235 inline? It is coming out of the 85 chevy. What problems might I run in to? Thanks for any suggestions, Kirk-KK2842 Abilene, TX |
I put the laughter n slaughter
Re: Needing Help on 62 chevy??
I put a 86 front end on my 63 chevy when i had it. Everything bolted up except 1 hole on each side. I used a booster and master cylinder from a
94ish comaro. ill post a pic, i think you can see the master cylinder. I didnt have any problems with the front end install though. I plan on doing the same thing to my 64 gmc. As far as the engine swap goes, i dont know what to tell ya, the 63 and 64 both had v8s in them before i got them.
I still dont care how you did it in California!!! ![]() |
thank, but how will this effect torsion bar set up?
kirk |
KK,
I removed mine, used a 86' front crossmember rotor to rotor, used the booster and master cylinder, used the fuseblock and wire loom, to include the steering column. It can be easily done, also put in a TH350 and older 350 then changed to a 700R4.
________________________ 62' ![]() 08' Chevrolet Silverado CrewCab 05'Toyota Tacoma Prerunner SR5 |
The torsion bar setup will be removed when you install the 85' front cross member, it has the coil spring suspension like all the rest 63-87 chevy trucks
Now that is the way to do it. I would say you saved some serious cash doing that way.
1950 Chevy 1/2 ton 283 Mustang II 1961 SWB 2x4 235 six 2007 Silverado 1/2 ton Z71 4x4 1968 Camaro SS 396 / 502 |
1962 C-10
My '62 is set up the same way. 73-ish front suspension, no more torsion bars, 70's style master cylinder and booster...
Joseph Chavez ![]() "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 Last edited by jchav62; 02-27-2008 at 02:18 AM. |
