Old 02-26-2008, 08:23 PM   #1
Alex1
Alex1's Avatar
Brake booster
Are there different sizes available? I have a 1980 and the brake booster is like 10-12" in diameter. I thought I had seen a newer pick up with a smaller booster on it. I would like to switch - I need more room for my turbo set up.
Any ideas?
Alex1 is offline   Reply With Quote
Old 02-26-2008, 10:17 PM   #2
454HO
Re: Brake booster
Why not Hydroboost? That would seem like the perfect setup for a turbo'd truck.
- Greg
454HO is offline   Reply With Quote
Old 02-26-2008, 10:58 PM   #3
Alex1
Alex1's Avatar
Re: Brake booster
Had to ditch the power steering too...lol
Old 02-26-2008, 11:08 PM   #4
454HO
Re: Brake booster
All you need is the pump. No room??
My next suggestion would be manual brakes.
- Greg
Old 02-26-2008, 11:18 PM   #5
Restrorob
The One And Only !!!
Restrorob's Avatar
Re: Brake booster
A higher powered engine with manual brakes ? Yikes !!!
With extra go you want extra woe.....
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 02-27-2008, 12:32 AM   #6
Alex1
Alex1's Avatar
Re: Brake booster
YEAH, that's why I'm looking into a smaller booster I need power brakes, this isn't a 2200lbs race car. I've found some universal boosters online (7") - I assume I could make it work!
Old 02-27-2008, 12:41 AM   #7
454HO
Re: Brake booster
A properly sized manual master cylinder can generate the same clamping force as a power assisted one. It just takes a little more effort to push the brake pedel. And since he has already ditched the power steering, I assumed he was physically capable of applying that additional push.
But your point about extra stopping power is a good one. I would suggest some larger diameter rotors on the front with some 4-piston calipers and an adjustable proportioning valve to set the front-to-rear bias.
- Greg
