02-26-2008, 10:34 PM | #1 |
Broken Door Handle
The Driver's door handle broke on the '69 C10. The button got smacked, and now the handle looks fine, but the button free floats inside. It looks as if the handle has a retainer or something that holds the thumb button in place and that is what is broke and lets the button float. (is this how it works)
I see that Classic sells the pair for $60. Has anyone tried these out? How well do they fit/work? does it come as one unit, or as parts to put together, whatever. (I guess what I mean is do you know if it will it solve my problem?) Or does anyone know where I can get one otherwise? I am keeping my eyes peeled at the local u-pull it place, but these trucks are showing up there less frequently these days. Thanks guys, Chris |
02-26-2008, 11:46 PM | #2 |
Re: Broken Door Handle
i was just checkin ebay out just now...and there is left hand and right hand door handles on ebay right now for like 20 some bucks.... lmc has some but they might be a high price...if you dont wanna fix it right away you can do what i did...i took out the thumb piece button and then its just a hole and then you stick your finger into the hole and push the lever that the thumb button presses...it dont look great but it works
02-27-2008, 01:36 AM | #3 |
When I got my truck my drivers door was the same way. There is a spring and metal piece that goes behind the button. It is held in place with a tab system. Look in the bottom of the door and if your lucky those pieces are there. Just put it back in position and use a small hammer to bend the tabs back or use a spot weld to hold it together.
Good Luck |
02-27-2008, 01:52 AM | #4 |
The Older Generation
I have the repo's on the white truck. They fit & work OK but the hole for the bolt that holds them to the door is drilled at the wrong angle, so they can be a pain getting bolted up. Maybe this has been corrected by now or someone makes them that are correct.... You can try what Robert8096 said. I have repaired them this way. You can't weld them though because the handles are pot metal. LockDoc
02-27-2008, 02:13 AM | #5 |
I stand corrected. LockDoc is right you can't use a spot welder. I used a small torch and a brazing rod.
02-27-2008, 03:12 AM | #6 | |
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. Last edited by Bob B.; 02-27-2008 at 03:12 AM. |
02-28-2008, 11:21 AM | #7 |
Thanks for the advice guys. I may try to look again and see if the pieces fell in the door or something. Or ebay. I'm not sure why I didn't look there before classic anyway...
And Tim, the idea of skipping it has been brought up as well... But I'd rather have it look/work properly. Although it might depend on how cheaply the handle can be found Thanks again fellas. |
02-28-2008, 11:41 AM | #8 |
I replaced mine on my "70" as they were pitted and the pass. side broke the same way as yours. I was happy with everything except the chrome. The finish is very thin, but chrome shops will not back up work with these type of handles where the button moves in and out. They like things that are disassembled. So if you get a good original make sure your also happy with the finish.
esll.
Tomorrow is for doing today's stuff. ************************************* This truck has just the right amount of energy for me! Author: Warren Lake .... (member) |
02-28-2008, 04:17 PM | #9 |
It can easily be repaired with donor parts.The problem usually is that the spring gets fatigued and either breaks or allows the button to travel too far and get dislodged.You can still push what the button pushed if the button isout of the way.
03-04-2008, 01:32 AM | #10 |
your welcome gibbelstein...i only had my handle like that for a day then my uncle said he had a handle just laying around at his house so i went and picked it up and put it on
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
