Junior Member
DJM 3" drop spindles?
They have two different versions for the 73-87. A 1" rotor version for $272 or the 1.25" rotor version for $229 at Summit.
My brain says go for the 1.25"s because of cost but I'm not sure if this is going to cause any clearance problems, etc. I dont mind spending the extra for the 1" if needed. I running these on a 68' with 18x8 coys up front. Anyone have experience with these? Thanks! Last edited by 68laydout; 02-27-2008 at 12:10 AM. |
![]() Join Date: Apr 2004
Re: DJM 3" drop spindles?
what size is your rotor? I would go with that size unless you plan to upgrade.
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
Junior Member
I planned on getting all new rotors/calipers to do the disc conv. Are the 1.25" for 3/4?
A guy with a truck
1.25" were standard until around '81 or so- then 1.25" became HD and 1" was the standard light duty rotor. Get the 1.25" if you're starting from scratch.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
Agreed.
i'm going with 1.25's, that way you can run 6 lugs up front.
1968 K10 burb- on it's way to being C10 sporting a 454 th400 and LTZ 20's 1995 K2500 Burb as daily driver 350 with 193K miles 1994 K1500 Silverado ECSB building a TBI 350 for it 330 horse |
Junior Member
A guy with a truck
No one makes a 1" 6-lug rotor that I'm aware of...
I have the 1.25 on my 65... I think you may have the prices backwards though... i am pretty sure the ones for the 1.25 are the more expensive spindles..
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=269019 Petitioning *No Regrets* MD/WV |
#10 | |
Junior Member
http://store.summitracing.com/partde...5&autoview=sku |
how are you getting these to fit your truck. Is your truck a 67-72? I'd love to be able to get that little extra drop
Make sure that you specify which ones very clearly to Summit. I ordered what I thought were the correct ones and they came to the house and were wrong... I sent them back and had to pay for shipping both ways... sucked but they claim it was my fault. Just make sure you specify very specifically which rotors youhave. Now that I think about it mine are the 1"
#13 |
You can change the control arms or you can get different ball joints and use the newer style tie rod ends.
#14 |
Junior Member
Yup, and I'm going the balljoint and tie rod route. I figured it was worth going with the 73+ for the extra .5" drop and parts also seem to be cheaper than the 67-72 stuff. I'm going to piece my front discs together from a 77 donor and the local parts store.
