Old 02-26-2008, 11:41 PM   #1
Blackbird66
Question about H pipe/ X pipe
For those of you who run these............What do you do about dropping the transmission? I'm running a 3550 tremec 5 speed, and tend to drop the trans about once every six months or so for something. My mustang was my only experience with a H pipe and it was bolt in. All the pics I've seen have not been bolt in. So what do you do to drop the transmission?
Blackbird66 is offline   Reply With Quote
Old 02-27-2008, 02:01 AM   #2
crazy longhorn
Fabricate till you "puke"
Re: Question about H pipe/ X pipe
My H pipe is bolted in(home brew).....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-27-2008, 02:06 AM   #3
67chevemall
67chevemall's Avatar
You may be able to run em, before or after the Tran.
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 02-27-2008, 02:19 AM   #4
72swb_327stroker_?
knuckle buster..
72swb_327stroker_?'s Avatar
do you have one yet?
or are you asking to find out if it will be worth your while to install one?
either way, have it flanged with ball joints, and you can unbolt them, remove the section to get access to your trans and be done with it!
don't use flat flanges with gaskets as they tend to be prone to leaking...
the ball joints are awesome! no leaks, no gaskets, no headaches!!!!
_______________________________________________________________________________
Eric
THIS SITE ROCKS!!!
Check out my suburban on 20's with fresh paint!
Click here to support the site
Check out the Member Photo Gallery here
StreetCruizin
FAQ thread
Site vendors list (scroll down to vendors in red)
join the the smilies fight club
72swb_327stroker_? is offline   Reply With Quote
Old 02-27-2008, 02:40 AM   #5
69halfton
69halfton's Avatar
....if your dropin the tranny that often. i wouldn't bother even installing a cross over. they are only good for like 1-2 hp or something. and true duals are way easyer to deal with for tranny stuff.
- Jason
If you can turn, Youre not going fast enough.
Favorite caption:
first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around..
..back when men were men.
69halfton is offline   Reply With Quote
Old 02-27-2008, 02:45 AM   #6
lilred67
lilred67's Avatar
i had my h-pipe installed right in front of the cross member for the trailing arms.it gives me plenty of room to remove my sm465 that i don't plan on removing any more than i have to. i know it's a little too far back from where everybody says put but, i didn't install it for performance. i installed it for sound control.
lilred67 is offline   Reply With Quote
Old 02-27-2008, 02:54 AM   #7
crazy longhorn
Its not as much about the hp, but the tork generated in the low/mid range that makes the diff.....an H or X also has a much "sweeter" sound. I run flat flanges, but with aluminum (Percys gaskets). They seal, & are reuseable....crazyL
Old 02-27-2008, 06:08 AM   #8
Blackbird66
cool, thanks for the info.
So where do you get ball joints? Any pics? I've never heard of such a thing.
Old 02-27-2008, 06:55 AM   #9
ChevyDude
I went X.
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
Old 02-27-2008, 08:18 AM   #10
72swb_327stroker_?
knuckle buster..
these things are awesome! here is the link:http://www.metexcorp.com/exhaust_decoupler.htm
but they are pricey, just go ball and socket if you don't want to pay the extra 100 bucks or so..get these @ jegshttp://www.jegs.com/p/Dynomax/753243/10002/-1/11527
this is a pic of a ball joint exhaust coupler
Eric
THIS SITE ROCKS!!!
StreetCruizin
FAQ thread
Old 02-27-2008, 08:19 AM   #11
suville
suville's Avatar
Google "header buddies" not positive thats the name but as I recall a company made these to use in exhaust fabrication.
suville is offline   Reply With Quote
Old 02-27-2008, 08:32 AM   #12
mfishburn
mfishburn's Avatar
Try some of those total seal exhaust clamps or straps. I dont know how well they work but they claim it seals like a weld.
1972 Chevy C-10 Fleetside
1979 Pontiac Trans Am
1980 Chevy Camaro (my dads)
mfishburn is offline   Reply With Quote
Old 02-27-2008, 09:28 AM   #13
Jim_PA
The magnflow kit I got came with this style clap (similar to the band clamp above) but these clamps actually make the pipes tight, as opposed to just forming a seal around them:
http://www.mandrelbendingsolutions.c.../Detail?no=375
I highly recommend these... the pipes on the magnaflow system have 2 slits towards the end that allow these clamps to clamp the pipes together, yet they slip back apart when you loosen the clamps.
I think my x is far enough back that I wouldn't have to remove it to get my 4 speed out though... certainly would be easy enough to remove if I had to though.
Jim_PA is offline   Reply With Quote
Old 02-27-2008, 04:52 PM   #14
Blackbird66
OK, so the ball joints look very much like what we use at the factory for some of the exhaust joints.
Again, Thanks guys, now on to the shopping list!
