Old 02-26-2008, 11:56 PM   #1
69heavychevy
69heavychevy's Avatar
need cam advice
Hi guys, i need some advice on choosing a cam for my truck. I have a mostly stock 350 with and edlebrock intake and 600cfm carb (will be upgrading to a 750), headers with 3in piping and flows dumped before the axle, and an hei distributor. I'm looking for something that makes good power between 1000-4000rpm, which i know doesnt narrow the results any. I just want something with some extra ooomph. Also i was told to go with a roller cam, but from reading around it seems expensive and complicated, whats your take. Been looking to get a kit with springs and lifters id figured that would be best. Im trying not to spend more than $400. any advice would be greatly appreciated.
69heavychevy is offline   Reply With Quote
Old 02-26-2008, 11:57 PM   #2
69heavychevy
Re: need cam advice
oh i forgot, i also have a th350 with open 3.73 gears (i think, not positive).
Old 02-27-2008, 12:16 AM   #3
PipsC10
PipsC10's Avatar
Re: need cam advice
I had really good results using the Edelbrock performer camshaft and lifter kit, especially in that rpm range. I don't think there would be a need to upgrade to a 750 cfm carb either. It is a mild cam that produces good lower rpm power, and maintains a smooth idle and plenty of vacum. Plus if your already running the performer intake, their made to match each other.
1970 2wd short/fleet 350/350 Project "iced green dream" http://67-72chevytrucks.com/vboard/s...d.php?t=272702
2006 Toyota Tacoma double cab 4x4
PipsC10 is offline   Reply With Quote
Old 02-27-2008, 12:40 AM   #4
Chevyholic
Will it run today?
Chevyholic's Avatar
Re: need cam advice
^^^^I agree that the 750cfm may be a little big for your setup. I've got roughly the same setup 350/mild rv cam/performer intake and I'm running 650cfm and I sometimes think I bought too big. I guess I'm hoping to grow into it someday.
Jaws, the 1971 Chevy Cheyenne Longbed.
She's big, grey, and has an insatiable appetite!
Chevyholic is offline   Reply With Quote
Old 02-27-2008, 12:47 AM   #5
Blue'72
Skinned knuckles
Blue'72's Avatar
Re: need cam advice
I had a Crane 268 hydraulic cam in the 350 in my Chevelle I just sold. It had nice power, but the 750 carb was too much and the gears were too high. It had a Performer intake and headers with HEI and supercoil. Flowmaster 2 1/2" exhaust too.
'72 C-10 longbox soon to be short step!
'72 Chevelle (sold in January)
'07 Sebring
'01 Ranger (I've gotta long commute..)
If you try to fail, and succeed, which have you done?
My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=276904
Blue'72 is offline   Reply With Quote
Old 02-27-2008, 12:49 AM   #6
Ole Blue 68
Ole Blue 68's Avatar
Re: need cam advice
Lunati Voodoo cam, love it.
Stick with the 600cfm carb.
Ole Blue 68 is offline   Reply With Quote
Old 02-27-2008, 01:03 AM   #7
69heavychevy
Re: need cam advice
i know this might sound childish, but i want something that sounds good. i=I had been leaning towards the edelbrock kit, i work at a parts store and i can get a good deal on it. ehat about the exhuast note, does it sound like you have a cam.
Old 02-27-2008, 01:28 AM   #8
ccd3
Re: need cam advice
Don't be ashamed- we're all gear-heads here. It's nice to have a little lope.
This may be only partially helpful. A year or so ago I was on a cam makers website- they had mp3 files of different motor/cam combos. I *think* it was the crane website- but it could have been Comp. Cams too... I have a somewhat lopey idle with the stock cam that comes in the 330 hp GM crate engine. It's a little flat until I get to about 1500- but after it's very nice.
I think it's a 212/224 grind?
No matter where you go, there you are.
ccd3 is offline   Reply With Quote
Old 02-27-2008, 01:34 AM   #9
malibu795
malibu795's Avatar
Re: need cam advice
i went form the performer cam 204/214 to 214/224 love the difference..
and i retarded the camshaft as well.
im running 8.5:1 cr as well. 600cfm carb on a 305 it pulls hard from idle to 5000-5500rpm
things to remmeber low compression love wide lobe seps... ie 112-114* the bigger cams run 108-110*
im runing a 112* i think my tq would im prove with the wider lobe sep of 114*
-A DAM WILD MAN-
59 apache pannel truck 38 I-6/sm420
79 malibu wagon 305/t56
02 2500hd duramax/allision 1/4 13.82 @100 mph efi live and built tranny
500hp 383 on the engine stand
U.S. Navy 2000-Current
Peace through Superior Firepower
Horsepower = Condom.....I would rather have it and not need it than to need it and not have it
malibu795 is offline   Reply With Quote
