Old 02-27-2008, 01:14 AM   #1
CJ5 Convert
CJ5 Convert's Avatar
Question Bed, wheel tub removal tips? gas tank removal.
Hey does anyone have any tips for holding the wheel well bolts while trying to undo the nuts from the other side. Also I'm just doing this to get to the tank on my '69 blazer to get it vatted is this the easest way?
- Jason
Orange Crush - 1969 K5 Blazer CST 4WD MONEY PIT
1975 CJ5 Renegade - Levi's Edition - 304 V8 original paint
CJ5 Convert is offline   Reply With Quote
Old 02-28-2008, 03:11 AM   #2
Big J
Its lookin' like a Blazer!
Big J's Avatar
Re: Bed, wheel tub removal tips? gas tank removal.
If the topside is solid enough you can spot weld the bolts in place and just hit them with the cut off wheel when your done.
BAZINGA!
My Build
Big J is offline   Reply With Quote
Old 02-28-2008, 03:43 AM   #3
vtblazer
vtblazer's Avatar
Tighten them till they snap off, then replace with new.
Simple, fast and easy.
But why not just drop the tank?
Reread your post.
Pulling the wheel wells won't give access to the tank either.
vtblazer is offline   Reply With Quote
Old 02-28-2008, 04:38 AM   #4
Big J
Big J's Avatar
Reread your post.
Tighten them till they snap off, hmmm.... Way easier, lol.
BAZINGA!
My Build
Old 02-28-2008, 04:52 AM   #5
vtblazer
vtblazer's Avatar
Yeah it really is, they bite down into the floor and hold till they simply break.
Lots of frustration saved.
Old 02-28-2008, 07:13 AM   #6
DANTES JIMMY
DANTES JIMMY's Avatar
I Always Used A Piece Of Flat Stock And Spot Welded Each One
Down The Line Kinda All Together 0_0_0_0_0
Guess I Never Just Tried To Break Em Off I May Just Do That Next Time
WAIT A SECOND WHAT DOES THIS HAVE TO DO WITH GAS TANK REMOVAL???
DANTES JIMMY is offline   Reply With Quote
Old 02-28-2008, 05:29 PM   #7
vtblazer
vtblazer's Avatar
Yeah, kinda waiting for CJ5 to jump in and 'splain it to us.
Old 02-29-2008, 03:57 AM   #8
CJ5 Convert
Well I think the bottom line is sometimes I'm stupid .
All, yall are totally right the long story is I have a parts vehicle that is super clean. I was going to swap the backend off of it onto Crush because I have no title for this really clean '72 ( got it out of Juarez) and Crush'es bed is rotted where the PO let water sit under the original glued down floor mats. It is rusted at the rear and around the wheel tubs.
What I was trying to do is kill several birds with one stone. Including swapping the bed, pulling the tank and getting it vatted/swapped which ever one was more economical, starting work on the rear right spring (it's sprung and I was going to start looking at putting on a 4" lift).
What I needed to ask was a seperate question saying. If I don't pull the bed do yall have any tips for getting that tak out of there with the least amount of problems. Also at what point do you not vat a tank and just replace it. Last who can I get a quality replacement from if I need to.
Thanks all- Jason
- Jason
