Hot Rods For Life
Spacers?
I am going to bolt down the 60/40 bench I got a while back from a 88-98 model truck. I will need to drill holes and get something to use as a spacer to keep it level. What should I use? I don't have access to a welder to modify or get new brakcets made. Washers seems ghetto to me. A block of wood doesn't seem sturdy enough. I gues wood could work or rubber. Any suggestions?
its all about the +6 inches
Re: Spacers?
Honestly, i used a short stack of washers on mine. Got a real big washer underneath to spread the load so it wouldn't get ripped out as everyone seems to be scared of... but in all reality, your seat belt would prevent that from ever happening.
Hot Rods For Life
Re: Spacers?
Yeah washers was my 1st thought. But like you said I wonder about the safety. I am pretty sure I'll go with the wasers.
Re: Spacers?
a dab of black paint will make them less obviouse to passengers
SLOW BUT SURE,BUT CLOSER
Re: Spacers?
Use some black iron pipe from the hardware store for your spacers and find some flat stock and make plates for the bottom. That should make it safe and strong.
69 C-10, OWNED 35YRS... 350 over 30, 350 Turbo, 3:73 Posi P/S, P/B Black with red and black int. ''LOVE THESE OLD ''TRUCKS....... ![]() ![]() ![]() |
member #16
![]() Join Date: Dec 1999
Re: Spacers?
I used a piece of xxx tubing, the I.D. was about 7/16" and 1" O.D. Solid mount, although I dont see washers being a problem. I did it mainly for looks.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
Happy to be here
![]() Join Date: Mar 2000
Re: Spacers?
Fender washer are cheap. Like mentioned above stack em up and paint em black...
I am a Referee of life.
Re: Spacers?
I saw one with a cheapie socket for a spacer.It had washers at both ends.3/8 drive so the bolt would fit thru.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" Last edited by PanelDeland; 02-27-2008 at 04:43 AM. |
Re: Spacers?
my local Lowe's has assorted aluminum, brass and steel spacers in 1/4" increments and various I.D. and O.D.'s ...
