Old 02-27-2008, 03:02 AM   #1
1971ChevyTruck
1971ChevyTruck's Avatar
Alternator Wires
I am installing wire loom over the front end wiring harness today. I noticed the wires for the alternator come off the same point as the driverside headlight. This would mean that the wires are routed over the drivers side of the motor. Is this correct?? Does anyone have a picture showing how they ran their wires??
1971ChevyTruck is offline   Reply With Quote
Old 02-27-2008, 04:28 AM   #2
Andy4639
Old member
Andy4639's Avatar
Re: Alternator Wires
The wires run down to the front of the driver's side fender then over to the rad support and tie into harness at the head light.
Here is a partial picture of the wires that hook to the alternator. The ones in the loom at bottom of pic.
Here is how my wires run to the driver's side. Top of rad support in the black plastic cover.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
