02-27-2008, 04:58 AM | #1 |
LED taillights need electronic flasher?
I'm interested in picking up a set of LED taillights. I've found a few suppliers for them and I'm getting conflicting reports that electronic flashers are needed (or maybe not ) for them to work properly. Does anyone have a definitive opinion on this?
TIA! |
02-27-2008, 06:00 AM | #2 |
Hollister, CA.
Re: LED taillights need electronic flasher?
I have the LEDS on the Chief....and they were great...they are SUPER bright.
I usually run without my hood, so I didn't have my front signals. The LEDS would not trip the flasher (would not flash...not enough current). So I picked up some resistors and hook them up to the LT and RT output to the taillights under the dash. It worked out perfect. Now had I of had my fronts hooked up, then I probalby would of need anything. A single 1157 per side, along with the LED should be enough to cycle a stock type flasher.
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
02-27-2008, 06:03 AM | #3 |
Talk to Musclerodz, he is a vendor on here and sells LED tails that have 40 LEDs in each one
here is a link to his profile link
CHEVY ONLY |
02-27-2008, 06:22 AM | #4 |
Resistance is Futile
........I used 2 1157 led replacement bulbs and have 60" wide LED bar and my stuff works fine.........no LED's in front.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
02-27-2008, 07:40 AM | #5 | |
Hollister, CA.
02-27-2008, 09:32 PM | #6 |
I bought mine from LMC when they had em, and runnin with the 2 1157's up front, there is no need for an electronic flasher, but there not exactlly super expensive to buy.
BRAD
2000 GMC Sierra EXT Cab Short 4x4, finally mine... 1966 C10 SWB Fleet, 250 I6, three on the tree.... Previously Owned.... 1987 Chevy R10 "Silverado" (at least the badges were) Short Step 350 700r4.... 1972 Chevy LWB Fleet 350/350 EXTENDED CAB ALL THE WAY! .._..~...-...._...____ .._..-...______|_|__\____ ..-..~.|_(O)__|_|__|_(O)] |
