02-27-2008, 05:34 AM | #1 |
inline?? OD trans TV to Offy 4bbl Intake
Guys I've searched but I have been able to find a thread on hooking the TV cable from an OD trans to the Offy set-up on an inline.
My Quadrajet sits sideways on the intake and the linkage movement is now East to West , instead of North to South. I'm using an extra long throttle cable to wrap around the carb, is there an extra long TV cable out there that will work , or a way to use a stock length? Thanks in advance! Zac
Working on my first 1,000 post. I'm sure I'll get there before this project is over . |
02-27-2008, 06:03 AM | #2 |
Old Duffer
Re: inline?? OD trans TV to Offy 4bbl Intake
I'm not sure what the answer is, but try www.stovebolt.com.
There's alot of tech threads there on inliners and various tranny's Good luck
'68 Short C20 Flatbed Dually w/ 292 4bbl, Langdon cast headers, and WC T5 trans. '81 G10 Shorty Van "Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers "Under promise, then over achieve." |
02-27-2008, 09:41 AM | #3 |
"Trucks with Class"
Lokar is the answer for the long cut-to-length cables.
I spend a lot of time figuring out the gas & trans cables for Offy/Holley & 700R4...and I started out with the solid rod to carb linkage...had to change over to the pedal w/cable 71-2 style. |
