Old 02-27-2008, 08:15 AM   #1
sleepertruck72
sleepertruck72's Avatar
Angry Block ID
I bought what some fool swore to be a Chevy 350 motor for my 67 project .
I looked up the numbers 18488572 and cannot find out anything about this motor. I guess for $100 bucks I should of just bought some beer and my headache would of been about the same, Any help would be great. Thanks
72 C20 Longbed
05 1500 Z71
sleepertruck72 is offline   Reply With Quote
Old 02-27-2008, 08:34 AM   #2
chev74
Addicted to Chevy
chev74's Avatar
Re: Block ID
i believe that is a pontiac block... dont quote me on that though
chev74 is offline   Reply With Quote
Old 02-27-2008, 08:35 AM   #3
chev74
Addicted to Chevy
chev74's Avatar
Re: Block ID
what color is it painted?
Old 02-27-2008, 08:46 AM   #4
Richard8971
Still livin the "dream" in '54
Richard8971's Avatar
Re: Block ID
Well, I am not sure about this but I came across a French site that says something about it being a Pontiac 350.
I don't read french well though.
Don
Current build. 1954 Chevrolet 3800 "Ella" SOLD!
My '67 stepper "Tangerine Dream"
"Anything worth doing is worth doing right" James Dean
“When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth.”
Sherlock Holmes
"There is no spoon." Neo
Richard8971 is offline   Reply With Quote
Old 02-27-2008, 09:27 AM   #5
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
Re: Block ID
Most Pontiac block numbers start with a 5. Some do start with a 9 or a 4, and a couple start with 3's. I can't recall any starting with 1. If it is a Pontiac, and it was made after 68, the cubic inch displacement will be cast into the driver side of the block just in front of the front freeze plug. Olds motor numbers start with 3, so rules that out. Buick maybe?
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 02-27-2008, 02:34 PM   #6
72armyswbtruck
72armyswbtruck's Avatar
Re: Block ID
If I remember correctly the Buick had the distributor in the front of the engine.
All Pontiac blocks have a hydraulic lifter valley pan. The distributor hole is located on the rear deck of the block which allows for the easy intake removal without disturbing the distributor
4th digit reveals that it should have been made in either 1978 or 1968 (look for the motor mount holes, should be 2 if 68 and 4 if 78)
2 freeze plugs 66 or earlier
3 freeze plugs 67 to 78
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 02-27-2008, 09:11 PM   #7
stope4
Re: Block ID
Isn't the pontiac transmission mounting to the engine different than a chevy?
stope4 is offline   Reply With Quote
