soon to be bagged64sub
1964 Suburban Parts
I just bought a 64 Suburban and was just wondering if anyone would happen to know of a company that has a good selection of parts for them. I have found some stuff but could use more. Any help would be appreciated.
1969 c-10, bagged, Zd, 20" Boyds SOLD! 1964 Suburban COMING SOON ![]() 1965 c-10 long bed 1993 Sierra x-cab 1999 tahoe-4/5 on 22s 2005 Chevy work truck |
Re: 1964 Suburban Parts
iT JUST DEPENDS WHAT YOU ARE LOOKING FOR............................FOR THE MOST PART FROM THE DOORS FORWARD IS THE SAME AS THE PICKUP TRUCKS.......hEMMIT
Welcome from another Suburban guy! Most of the truck places carry some burban parts, like weatherstripping, tail light lenses,etc. But some of the unique parts I'm still looking for sources on. Is yours Chevy or GMC?
Greg 64 GMC Suburban - 283, NV3500, 14 bolt 77 C10 swb - 292, SM465, 12 bolt |
Its a Chevy. I have found weatherstripping and window rubber as well as floor pans. But I haven't found body mounts or much else. Where did you find the lenses at.
Resistance is Futile
I found my tailite lenses @ Brothers........screws @ hardware store as mine had 6 different screws!!!
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
Lenses (front park and tail) I found at Classic Parts (www.classicparts.com). Both worked well, and the tail lenses are an exact match of the originals. Same here on the screws, Protrash. Phillips and slotted assortment.
I'm also looking for body mounts for the rear portion of the body. The front stuff is the same as the pickup. I want to separate my body and chassis, but if I do that, I'm putting it back together with new mounts.
![]() Join Date: Sep 2007
I will tell you what I know about the rear body mounts. They are not made in the after market. Or at least in my over a year of searching they are not. I'm having mine made at the shop that is doing some other work on my 61. I've found the best quarter window seals at Steele, and found a good front rubber mat, although the link is some where saved on this computer. Also the window locks are not made after market as well.
Thanks for the help. Im building a new frame so I wanted to try to track down the mounts before I finish the frame.
