Old 02-27-2008, 08:52 AM   #1
OldCreek
OldCreek's Avatar
ubolt size
Need a verification on ubolt size for H052 axle.
I'm measuring 3.30" diameter. (I've found some of these made by Rancho.)
I've some 3.375" (3 3/8" ) in my possession.... can I use these? Or, does the tolerance need to be exact. I've plates that would fit 3 3/8... probably fit the 3.30" also.
Also, can someone verify the 4th Ubolt on the passenger side of a D60 needs to be 4". The other 2 I have are 3 1/8" for the driver side.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 02-27-2008, 05:55 PM   #2
dinotruck68
dinotruck68's Avatar
Re: ubolt size
why dont u just get em made 4 you? thats what i did cost a bit more but they're a whole lot stronger than the stuff the lift companies sell.you check out ur local bolt an screw shop
dinotruck68 is offline   Reply With Quote
Old 02-27-2008, 07:16 PM   #3
Burt4x4
Burt4x4's Avatar
Re: ubolt size
That is preety close, you could prolly get away with them working, just make sure you keep um torqued and re-check the toruque after a bit
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 02-27-2008, 07:39 PM   #4
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: ubolt size
I'd definitely use the ones you have, when you torque them down it will tighten them around the axle tube just fine.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
