Old 02-27-2008, 08:52 AM   #1
bomar
bomar's Avatar
steering box
will a 73 -87 power steering box bolt directly on my 72 frame thats power steering and use the same steering shafts
bomar is offline   Reply With Quote
Old 02-27-2008, 09:14 AM   #2
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
Re: steering box
yes it will bolt up, but...after 76 IIRC the lines were changed to a metric(?) and that would take some fanagalin' to get working, but it can be done.
Ideally, you should look for a 76 box because that will give you variable ratio, and true bolt in conversion, even using your old lines.
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
