02-27-2008, 08:02 PM | #1 |
windsheild washer pump
when i push in the button, all the thing does is click and nothing comes out. anybody else have this problem?
02-27-2008, 08:29 PM | #2 |
Old member
Re: windsheild washer pump
More than likely the rubber orffice has let go so it can't pump. I had this happen to several of mine so I installed a late model jug with electric pump on it. It works so much nicer. I wired it to the factory switch also.
02-27-2008, 10:28 PM | #3 |
Between Trucks...
Sounds like a great idea, any details on the install?
Beat it to fit, Paint it to match... |
02-28-2008, 07:57 PM | #4 |
yea, i picked a universal pump a few months ago from a flea market. It looks like it will work with my old pump, but i have t wire it to the old pump. which wires do i use? the pump has a 12v+ and a ground. the directions say to wire it to the 2 wire plug going into the old pump, but when i remove it, the windshield wipers dont work. there is also a single plug with a black wire and a 3 wire plug with a blue wire and 2 yellow wires. any help would be great!
02-28-2008, 08:12 PM | #5 |
Old member
Sorry,
wish I could help but it's been a long time ago since I wired it up I don't remember how and what color's.
