sparkplug wire looms
what did you use for wire looms or seperaters for under the header routing of your sparkplug wires. what do they attach to?
thanks, Gary |
Love That '69
Re: sparkplug wire looms
I can get you pictures later, but I have these chrome bowtie wire looms on my SBC. These use the existing (2) outer valve cover bolts. The holders slide in and are press fitted; they have yet to come loose. You gotta watch though, most wire looms only fit up to 8 mm wires, you need a special kind for larger wires.
![]() I also have these for extra protection from the heat from my headers. They fit on the spark plug wire boots (straight or angled). They are made from a fiberglass composite material and protect to 1200 degrees. ![]()
I AM CANADIAN!!!!! ![]() 1969 Chevy C/10 Truck - SBC V8, TH-350, 3.73 Posi, 1000W Rockford Fosgate Stereo System, B&M Megashifter, GT Grant Steering Wheel, Dual Magnaflow Exhaust System, Dynomax Headers, Lowered 1" Front & 3" Rear, Front/Rear Sway Bars, Racing Seats, 6000K HID Headlights 2008 Chevy Colorado LT - 3.7L I5, 4 Speed Automatic, Crew Cab, 4X4, Z71 Off-Road Package, "Ground Effects" Package, K&N Cold Air Intake, Supermod PTB, Magnaflow Exhaust w/ Resonator, 500W Kenwood / Rockford Fosgate Stereo System, Custom LED Lighting, 6000K HID Low's / High's, Blackcat Customs Gauges / Needles, Carbon Fiber Interior Accents, KrFabs 2" Lift Shackles / Torsion Bar Crank with Rancho RS5000 Shocks, Superskids Skid Plates Last edited by Classic69; 02-27-2008 at 09:31 PM. |
Nothing to see here.....
![]() Join Date: Jun 2007
are you wanting to stay stock?
if so, Classic Industries has the most extensive line of stock mounts I have ever seen.....
Doug ![]() ![]() The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
not much stock left why stop now. just don't know. looking for what others have done.
gary |
It's Done When It Runs!!
Here's what I have, I have centerbolt valve covers though.
For under the header, I just used small zip ties to make a harness out of the wires. I attached the so-called harness to a small metal bracket I bolted to the side of the block.
Hidden plug wires are the way to go! ![]() |
knuckle buster..
![]() Join Date: Oct 2007
here is my set-up, basically the same as classic69.
_______________________________________________________________________________ Eric THIS SITE ROCKS!!! ![]() Check out my suburban on 20's with fresh paint! Click here to support the site Check out the Member Photo Gallery here StreetCruizin FAQ thread Site vendors list (scroll down to vendors in red) ![]() ![]() |
LAIDOUT
I have the ones like 72swb_stroker, they do the job nicely and keep the wires off the headers. I got mine in red from Summit.
is Certifiable
Summit has some really nice ones. Here are a few links of some clean looking looms.
http://store.summitracing.com/partde...5&autoview=sku http://store.summitracing.com/partde...5&autoview=sku http://store.summitracing.com/egnsea...s=P%5FRank%7C0 |
LAIDOUT
Not a great photo, but here are mine.
I just got 4048 accel wires from advance auto part and msd billet cap and rotor kit from autozone then to advance can eat a dick auto zone is where it's at
Did a tune up from auto zone they have all the parts i need to keep my truck running accell and msd parts advances had to ord parts for my truck and autozone has the parts in stock
#13 |
Although I enjoy the hilarity in reading your 'eat a..' statement above mike.. remember this is a family friendly board. I can honestly say that statement is something I myself use on a regular basis though.. just not the right place for it. lol
That being said.. all you guys with perimeter bolt heads got it made. I haven't found anything I like for centerbolt heads yet.
1972 Long Bed Cheyenne Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=285282 Waste my bandwidth and listen to some great tunes >> http://www.radioxenu.com (Live Shows with yours truly every Friday) Last edited by 420am; 01-17-2010 at 05:19 AM. |
#14 |
![]() Join Date: Feb 2008
Here is my setup. I made a custom loom similar to the ones on the market but it bolts under the center cap on the valve covers. I was trying to achieve an "old school" look.
#15 |
That's a very clean and unique way of running the wires. What did you purchase and what did you make?
#16 |
I have Billet Specialties that match the valve cover and air cleaner...
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
#17 |
I purchased the cap that sits on the top of the valve cover off of ebay. They are aluminum and I had to polish them. The valve covers are center mount so they attach under the cap. I added the GM 350 sticker to make it look more authentic. I then made the "wire holders" out of 1/4" PVC sheet and the "loom holder" out of .100" aluminum on a CNC router.
